BV43A VNT Actuator Adjustments
CarlosVW
Mayfield, Kentucky, USA
05 VW Passat 2.0L TDI /BHW engine code/ BSM deleted/ Malone Stage 2 Custom/ Stage 2 Colt Cam/ BV43A turbo upgrade/ Bosio 1043 Injector Nozzles
Hello,
I am needing some help about whether the adjustment/calibration on a BV43A actuator and the GT1749 actuator are the same? Mine DOES NOT have the electric sensor on top, it looks similar to the GT1749 actuator but not quite.
A5INKY
Vendor , w/Business number
Louisville, KY
2006 Jetta TDI, 2002 Eurovan Westphalia VR6
Principle is the same. The "smart" portion of those actuators that have it has nothing to do with mechanical set-up.
CarlosVW
OK, I keep getting a under boost code, do I lengthen to increase boost at low RPMs or do I shorten it? Do you follow what I am saying?
Sent from my XT1053 using Tapatalk
A5INKY
Louisville, KY
Don't adjust anything until you run a WOT group 11 log, 3rd gear from 1500 RPM to redline. Email or even post it up and I can tell you if an actuator rod length adjustment is needed.
CarlosVW
I sent it to skunkwerx email address.
