Old June 19th, 2011, 19:04   #1
srmichi
srmichi's Avatar
TDI(s): 01 golf
Default Urgent clutch master cylinder leaking
Okay here is my problem I just changed the clutch master cylinder and when I go connected the lines in the engine compartment. The solid line that goes into the master cylinder keeps leaking. I took it out and notice no o-ring so I put one in and it still leaks. It's already 9 and I need the car for work tomorrow. Does it have more than one o-ring?
srmichi is offline   Reply With Quote
Old June 19th, 2011, 19:30   #2
srmichi
srmichi's Avatar
TDI(s): 01 golf
It leaking from the connection.
Old June 19th, 2011, 19:35   #3
srmichi
srmichi's Avatar
TDI(s): 01 golf
When I took it out from the old master cylinder I did not notice a o-ring. I put one on the first grove from the tip since the last grove is for the clip that holds it in place.
The black plastic on the end spins is that normal?
Old June 19th, 2011, 21:50   #4
srmichi
srmichi's Avatar
TDI(s): 01 golf
well i guess ill have to go to the parts department tomorrow morning and hope they have that line and check how that plastic thing keeps it from leaking brake fluid everywhere.
Old June 20th, 2011, 06:41   #5
srmichi
srmichi's Avatar
TDI(s): 01 golf
Well I'm at the part department and they don't have it so I can't check if I lost anything.
So does anyone that changed their master cultch cylinder please let me know if I'm missing something.
Old June 20th, 2011, 22:03   #6
srmichi
srmichi's Avatar
TDI(s): 01 golf
so no one on here has replace there clutch master cylinder?
Old June 21st, 2011, 01:37   #7
jimbote
jimbote's Avatar
this type of line does not have an "oring" it has a little rubber nipple that is still inside your old master cylinder or it fell out somewhere
Old June 21st, 2011, 15:12   #8
srmichi
srmichi's Avatar
TDI(s): 01 golf
Thanks for the response. So there is a rubber nipple that goes in between the cylinder and the plastic part? Is there a way I can buy one ore is it part of the hose?
Old June 21st, 2011, 15:20   #9
Victor Huge
Victor Huge's Avatar
TDI(s): Mk7 Golf TDI
I was told that the slave did not have an o-ring when I replaced it, it did, but none came in the box. I was also told that the master did not have an o-ring, this time though it came with one in the box. Say yes to O-RINGS!
Although, I must admit, the ends on mine were silver and metal, not black like yours.
Victor Huge is offline   Reply With Quote
Old June 21st, 2011, 15:56   #10
srmichi
srmichi's Avatar
TDI(s): 01 golf
well the funny thing is that the end that goes into the slave is metal with an o-ring. but the one that goes into the master is a hard plastic pieces that is sliced in four pieces toward the line and now im leaning toward the nipple since the o-ring i got at the dealer still leaks. i guess ill go down to the part department again tomorrow and figure out whats missing. just hope i don't get the cold German woman that makes me scared to ask to many questions.
Brake master cylinder/clutch master cylinder? dweisel VW MKIII-A3/B4 TDIs 16 July 2nd, 2015 20:09
Clutch master cylinder or Slave cylinder, Which is FAIL ? Mcgink VW MKIII-A3/B4 TDIs 22 November 26th, 2014 14:34
Clutch Master Cylinder Herm TDI VW MKIV-A4 TDIs (VE and PD) 16 February 2nd, 2013 14:51
clutch master cylinder jcfone VW MKIV-A4 TDIs (VE and PD) 3 December 17th, 2010 11:30
Clutch Master Cylinder vacman VW MKIII-A3/B4 TDIs 0 July 21st, 2007 22:04
Page generated in 0.15772 seconds with 11 queries
[Output: 95.65 Kb. compressed to 80.97 Kb. by saving 14.67 Kb. (15.34%)]
