Old September 21st, 2010, 06:32   #1
Little Pickle
Little Pickle's Avatar
Default MAP upgrade?
Hi folks
Now I have my 1z Hybrid turbo working correctly and the car is running great after sorting my dodgy N75 valve and I'm very happy with its performance.
Does anybody know if my Bleached Bora Hybrid will top out my 2.5bar MAP sensor in the ECU? I was thinking about swapping the sensor for a MK4 sensor to milk that turbo for every last drop of air. Anyone know how far I can push this hybrid, 1.5, 1.6 bar?
I havent a boost gauge setup yet which I know is pretty vital.
Thanks in advance
Seat Arosa 1z TDI. BB K03 Hybrid Turbo, 2.5 downpipe, PD lift pump, Custom re-map, PP520, Green cone airfilter, EGR delete, De-cat & boxes, FMIC from a Renault Master, Sparco Milanos, KW Variant 3 coilovers, 288mm Brakes, 320+NM, 150ish bhp.
Little Pickle is offline   Reply With Quote
Old September 22nd, 2010, 01:17   #2
im570rm
1.5 bars is the max you can push on that turbo...so 2.5 bar map sensor is fine
Audi a6 avant 2.5 tdi quattro
EX Alfa romeo 156 sw 2.4 jtd with 2260vk water cooled
EX Seat Leon 1.9 TDI ASV
im570rm is offline   Reply With Quote
Old September 22nd, 2010, 01:29   #3
mojogoes
TDI(s): mk3 tdi golf
Fuel Economy: not much
It will allow you to be able to push out half a bar more pressure with out going into limp mode but your turbo will grenade in the very near future..........if you wanted to boost to say 20psi which some have done in the good old days with out too many problems you can pipe in a bleed valve about 4" away from you ecu/map with the same out come!!
A3 / mk3 golf with 249Whp "Now in the hands of someone else"
mojogoes is offline   Reply With Quote
Old September 22nd, 2010, 08:42   #4
Little Pickle
The bleed has to be no more than 4inches away from the ECU?
Old September 22nd, 2010, 12:21   #5
mojogoes
Sorry yes 4 inches not 4 feet
Old September 22nd, 2010, 12:31   #6
Little Pickle
Does the distance really matter? Mines about half way between manifold and ecu.
Old September 22nd, 2010, 13:12   #7
mojogoes
Yes as it will react better at 4' away from the ecu/map sensor than where you have it.........where you have your bleed is usually where one would fit a dawes divice / mechanical boost controller.
Old September 23rd, 2010, 05:36   #8
Little Pickle
I moved it to 4inches away this morning and boy did I notice a difference!!
Page generated in 0.15546 seconds with 10 queries
[Output: 81.87 Kb. compressed to 69.61 Kb. by saving 12.26 Kb. (14.98%)]
