Dwagen
- Joined
- Nov 25, 2018
- Location
- United States of America
- TDI
- 2004 VW Jetta GLS TDI; 2013 VW Jetta Sportwagen TDI
DSG Tranny Hanging/Jerking/Smoking Under Hard Acceleration: Now Code P0544 & GP Light
Hi guys. I have a 2013 VW Jetta Sportwagen TDI with the dual-clutch DSG transmission. I got it a few months ago at 68K miles, and it currently has 73K miles. This has been an ongoing problem ever since I bought it. I drive my vehicle conservatively most of the time and usually drive in manual mode, upshifting at the earliest opportunity for fuel economy.
One time I was in 2nd gear and floored it. When it reached redline, it just hanged there. I let off, waited a second, than slowly accelerated again. Then it shifted down into 3rd gear like normal. I experienced this a couple of times, which irritated me to say the least.
Another time, I was in 1st gear turning into an intersection (this was a sort of blind intersection). After I pulled out, I noticed a Prius coming over the hill, so I accelerated fairly quickly so he wouldn't have to slow down. It reved to redline and bounced off a few times, then violently lurched into second gear. By violently, I mean there was a clunking sound, the tires squealed, the vehicle jerked, and a cloud of white smoke was coming out from behind my vehicle. This also happened a few times, which concerned me much. To me, I was thinking it was perhaps the clutch or something (while praying it wasn't)... it felt like the transmission was acting up.
Finally, last week I was driving with a friend. I was in 6th gear and decided to demonstrate the kickdown button function. It went into 3rd gear, jerked a little, and simply lost power (revs quit climbing). I quickly shifted all the way back into 6th gear and noticed a WHOLE LOT of white smoke coming out from the back of my vehicle (not because I shifted back into 6th). It was thick. Then I noticed my Check Engine Light had turned on and my Glow Plug Light was flashing. I pulled over and inspected the car; no fluids were dripping, nothing smelled like it was burning, coolant level was good, engine was running fine. Afterwards, I've been taking it easy. When accelerating, it just doesn't pull with the same power like it used to (I only noticed this once when accelerating harder than usual). Maybe the car's in Limp Mode...? Except it feels like it's driving normally.
Also, all of these instances happened in Manual mode. I've never experienced this in any other drive mode. I've been researching for days and can't find anywhere of anyone else experiencing the problem I'm experiencing. I checked the engine code, which is P0544 - Exhaust Gas Temperature Sensor Circuit Bank 1 Sensor 1. I'm taking her to the dealership tomorrow to have it replaced under warranty.
I really want to get to the bottom of this issue. I don't know if this sensor has anything to do with the previous (what seems like transmission) issues I've been dealing with, or if it's just coincidence. Just the fact that the lights came on right after the transmission acted up is puzzling to me. Last time the DSG fluid's been replaced (as far as I can tell from Carfax records) was... never. Last time the fuel filter's been replaced was around 45K miles. Based on my research and what different people are telling me, new DSG fluid might be needed but won't necessarily fix the problem. IF it is the clutch I'm feeling jerking/clunking, then I might need a new clutch... which is expensive... but how did the clutch get to the point of needing replacement at only 73K miles?? Perhaps the fuel filter is clogged and needs to be replaced? I can't tell if it's just one problem or a combination of problems... I have a feeling it's a combo since I couldn't find anyone else with quite a problem like mine.
Additionally, sometimes when driving between 5-10 mph, my revs go up and down when driving a constant speed. Other times when driving around 5 mph without touching the brake or gas pedal, the transmission feels jitterry, like it's shuddering. But as soon as I start applying a little braking, it immediately goes away. Maybe that's just normal for a dual clutch... that's what I've been thinking about a lot of the issues I've experienced but now I'm not so sure.
Thank you so much for any input you may have. I've been keeping this in for some time, but I'm letting it out hoping someone can help me here.
