Old August 12th, 2017, 19:30   #1
carsaremytoys
Default Rear coilover install issue
The coilovers are JOM btw. The issue is that the spring perch is too small in diameter to go around where the factory spring sits ( I can't think of the correct term ATM) . There is a shim piece of steel that looks like I need to knock off to allow the perch to fit properly. Before I whack this piece out, I want to be sure this sounds right..
carsaremytoys is offline   Reply With Quote
Old August 19th, 2017, 14:37   #2
carsaremytoys
yep, you have to knock this off :
http://www.idparts.com/rear-lower-sp...a4-p-1345.html
ST coilover install/setup question Yai Ontario 4 April 29th, 2016 16:16
Coilover install, spacers needed?? TDIClimb VW MKIV-A4 TDIs (VE and PD) 1 January 5th, 2015 11:01
St Coilover Suspension - Complete Install! - MK5/MK6 - Kansas Cj98 Private TDI Items for Sale/Wanted 0 August 5th, 2013 18:39
Sway bar rubbing after coilover install, will adjustable endlinks help? FolksWagen VW MKIV-A4 TDIs (VE and PD) 2 May 24th, 2011 09:08
Coilover Install/Setup H&R Dune Buggy VTJC Upgrades (non TDI Engine related) 5 April 15th, 2004 12:43
Page generated in 0.13518 seconds with 11 queries
[Output: 51.48 Kb. compressed to 47.58 Kb. by saving 3.90 Kb. (7.57%)]
