Is there a quality dry filter that doesn't need replaced basically every year? I guess I could retrofit one of those flow meters to get the most out of the stock filter.
I guess spending $12 a year is too much...
Considering the stock (Mann, Hengst, whatever) air filters are really good for something like 80,000 miles (depending on the ambient dust conditions), for what you'd spend on the air flow meters, you may just as well just replace with a stock unit every 1-1/2 to 2 years...
BTW: many people feel that the air box should never be opened unless you're replacing the filter, as the seal will have conformed itself to the box and will no longer function as well...
Yuri
