sqdude
Howdy,
My brother just got a 2000 Jetta TDI, Automatic with 175k miles. It's been maintained well and was running great for the first couple days.
On Saturday it started making an absolutely horrible noise each time it starts (doesn't matter if engine is warm or cold). It's so startling that I almost jumped when I turned the key the first time. It's NOT the normal TDI starter noise you get when the engine catches and the starter does a little ERRRRRRR.
This noise sounds like a piece of wood or metal that's been thrust into a fan. It's metallic and rotational. As soon as the engine catches and you release the key from the starting position, the noise stops. The engine sounds 100% normal once it's running.
This is my first time messing with an automatic. I don't think my 5-speed has the little sight hole down on the tranny? Maybe something fell down in there? The car has the top engine cover but no skidplate at all.
Thoughts?
Thoughts?
