madcowintucson
It does not allow fuel after its unplugged, it dies just like every other pump thanks to vw.
Yea and when our water pump fail and it stops circulating eventually like every other pump we'll blame VW also.It does not allow fuel after its unplugged, it dies just like every other pump thanks to vw.
lol @ you thinking the impeller has anything to do with the waterpump failing.Sure my friend please educate me in my other plug and play options. While you are at it, be sure to use a 40,000 mile plastic water pump impeller instead if the metal one on your next timing belt job, I am positive they last just as long and are just as reliable as the 100,000 mile units
The odds of the impeller coming off the shaft are extremely low, plastic/metal doesn't matter. Now the bearings going bad and the WP leaking down the front of the engine is a reality. Most failures are because of this, not the impeller. Keep regurgitating stuff you read on the internet to make yourself feel smart.You are telling me that when the plastic impeller cracks and breaks or comes off the shaft thats not a failure? Yeah thats a failure here on planet earth, so lol@ you living in a fantasy world.
I don't know if I should laugh or cry at your utter stupidity.I guess jealousy is what becomes of people living in canada-A...Over here in the United States of America we get good metal bearings and our vw water pumps never leak, so we can again blame vw for supplying canada with crap bearings but apparently great impellers, hey maybe you all get plastic bearings? thanks vw!!!...keep regurgitating stuff you read on the internet to make yourself feel smart.
I am now having the exact problem I was trying to avoid by installing a PD lift pump. If I do a wide open throttle run in 3rd gear the car pulls all the way to redline very hard with a very rapid rate of acceleration. When I shift into fourth and go wide open throttle the RPM's rise quickly until I hit around 4100 rpms rpms and they just level off there and won't go any higher even at full throttle on a long stretch of road I believe is a fueling issue. I have sent logs to my tuner but I am still waiting for response.
If it pulls all the way to redline in 3rd, it should pull all the way to redline in 4th. If it were a fueling issue, it should happen in any gear.
Sure, the fuel into the injectors is more, but the actual fuel flow into the pump is actually the same rpms for rpms, however the flow back to the tank will be less. Heat-soak is definitely a possibility and that's what i was getting at earlier. the load on the motor to overcome at high speed is greater, I suspect you may not have the power to rev fast above 4100 rpms in 4th, i know my car will not get there fast at all, but i could be completely wrong about your setup. On that note, have you checked your fuel filter at all? I met a guy at the airport one night when it was very cold and his car would barely idle, he tells me he just ran b100 and even changed the filter, but the car wouldn't hardly rev, i pulled out vagcom and at idle everything was normal, he had another new filter in his car, i suggested we do a swap and i would stay and help him, after the swap to the new filter the car ran normally and revved freely. All that old me was the fuel was not gelled in any way and the filter was plugged, a common side effect after running b100. Also if you floor the engine do you see black smoke? if there is never black smoke then the engine is not over-fueled, if you floor it in 4th and see black smoke then obviously the injectors are dumping enough fuel to run rich. i can tell you that in my car without an inter-cooler i do not have enough air density to burn all the fuel and therefore have limited power potential, also egt goes up, but this is only in 4th and 5th gear on the highway, in 1st through 3rd i have enough gear multiplication to spin the turbo at faster rpms thus allowing more air to enter and exit the engine/free'r breathing. So i am dumping more fuel through the injectors but the vehicle revs fast enough to maintain a different air density. 20 psi at 1000 rpm is very different than 20 psi at 5000 rpm.I thought the same thing. The only variable is the load the engine is under. In 4th you are going much faster than 3rd at the same rpm so it should take more fuel. That is the only idea I could come up with for a reason it is happening.
Anyone else have any ideas?
While my runs were done at night, it still was 90 degrees outside. Could I possibly be looking at a heat soaked intercooler? Would it be that drastic of a drop off?
I an running a 17/22 at 27 psi with a factory intercooler.
My fuel filter has less than 600 miles on it. I can not tell if there is much as far as black smoke because I have only driven it at night.
The thing that is so confusing is how quick and relentlessly the thing accelerates in third. The rpm's climb from 2k to redline so fast it is amazing.
No offense but you look like a complete jack *** right now.I guess jealousy is what becomes of people living in canada-A...Over here in the United States of America we get good metal bearings and our vw water pumps never leak, so we can again blame vw for supplying canada with crap bearings but apparently great impellers, hey maybe you all get plastic bearings? thanks vw!!!...keep regurgitating stuff you read on the internet to make yourself feel smart.
