an60an
First I would like to say that I've tried to search for this issue but I couldn't find a problem like mine, maybe is just me.
The car is 1999 Golf TDI, 5 speed manual.
I do have a boost pressure gauge and a boost valve, limiting the trubo's boost pressure to 18psi installed by the previous owner.
For the last few days the boost just cutting off. If I start accelerating the car the boost gauge showing increase up to around 5psi and after that just cut off and goes down to 0. One way of resolving the issue is to stop the car and restart the engine. I re-checked all the vacuum hoses and re-installed them now they are tight and with no leaks (I tried with soap water) however the problem still exist. In the morning when the engine is cold, no problem at all as soon as the engine get up to normal operating temp... here we go. On the long runs I don't have issues maybe because the engine is working above 2000RPM?? I don't know please help.
Antony
Antony
