bulldogbones
Well today was fun driving 75 miles home in limp mode. My cheapo scanner pulled those codes. I just ordered a VCDS but in the mean time what else can i do to figure out whats going on.
It did have the emissions flash done to it. But I cant figure out if that is covered under the extended 10yr 6mo or 126k miles warranty, i doubt it but im still researching that.
2012 passat
Bought it in april of 2015 with 52k miles
Currently 314k bone stock.
On the side of the road
p0401 -
p240f
p2201
p0641
Checked after I got home.... Houston this just got bad
P0641 - CNF - SENSOR REFERENCE A VOLTAGE CIRCUIT OPEN
P0300 - PND - PND - MULTIPLE MISFIRE
P0301 - PND - CYL 1 MISFIRE
P0303 - PND - CYL 3 MISFIRE
P0304 - PND - CYL 4 MISFIRE
P0302 - PND - CYL 2 MISFIRE
P026A - PND - PND -AIR COOLER EFFICIENCY BELOW THRESHOLD
P0401 - PRM - EXHAUST GAS RE-CIRCULATION FLOW INSUFFICIENT FLOW DETECTED
P240F - PRM - EXHAUST GAS RE-CIRCULATION SLOW RESPONSE
This make me think clogged DPF???
2012 passat
p0401 -
p240f
p2201
p0641
