[ QUOTE ]
I have no idea where that rumor of 4 sprays to every 1 headlight spary came from. It's not true. Your headlights get sprayed every time you spray your windshield (when your lights are on...).
[/ QUOTE ]
Oh, I read the following on the first post on the first page here on this thread:
[ QUOTE ]
If you want to wire the kit the same as the factory installation, (Downside of the hella retrofit kit is that your headlights get sprayed everytime you clean your windshield. The OEM install only sprays your headlights when the lights are ON and every 4th time you squirt the windshield. The Hella way, everytime, you'll go through fluid like crazy.), you will also need:
1J0 955 531 "Relay 192", (if you have any plans to use the rain sensor gizmo with your windshield. If you don't have the rain sensor you will lose the intermittant function of your wipers with the "192" relay.), or;
4B0 955 531 E "Relay 603", (this relay is the one for headlight washers with no rain sensor.)
[/ QUOTE ]
So even if I am using the OEM relay/control module (Relay 192 or Relay 603), the headlight washer will spray everytime I spray my windshield, right - that's the OEM way too?
