Powerstroke9773
- Joined
- Feb 2, 2015
- Location
- North Carolina
- TDI
- 2002 Jetta TDI (totaled parts car) 2003 Jetta GLS TDI
Another issue I'm hoping the fine people at TDI Club can help me out with. I researched how to hook up the gauge in my 2003 Jetta and found a w/u saying to wire the power and ground into the dimmer switch. Big mistake only works with headlights on now. Second issue is it only works sometimes as in when it doesn't work it flashes so bad I feel like a army of Policemen are behind me and it makes it a nightmare driving at night. Its like its stuck in its startup sequence. When it does decide to work the boost gauge doesn't really work the EGTs work fine but boost keeps creeping up to 30 unless I romp the throttle hard I grounded the sensor to the battery. And have all wires hooked up correctly as far as I know just wanting to know where the best part under the dash is to hook up the power and ground for the gauge that has power as soon as the car is turned on. Thanks in advance
PS I also looked up the McNally installation guide and it tells you to find a good place to hook it up not a specific wire to tap into or anything like that.
