PRY4SNO
Took the car in for a warranty service to remedy some codes (P0401, P0674, P2002, P1005, P1006) and they're stating that there is a poorly repaired harness affected by "outside influence" and as a result they won't warranty the repair. Not sure what to say, as I didn't do that repair and we bought the car used without any service records so it's most likely that was there from before.
My options are to pay over $500 to repair about 10 feet of harness to VW spec and then they'll continue to diagnose (force regen, etc) the EGR/DPF issues. The wiring goes to the exhaust flap (already replaced during recall). No word on the glow plug wiring or the detected torque differences in cylinder 2 and 3.
Couple questions.
Service advisor said on the phone that they noticed the wiring when the car was in for emissions recall and didn't say anything to me or VW. Say what? A) why not tell me at the time so I can fix it and ensure the car is compliant? B) isn't it their problem now, since they knew about the issue, didn't advise me, and carried forward with the emissions recall while aware of the issue?
I've already cashed the settlement cheque, and have documentation from VWoC stating I have a valid extended emissions warranty. Which now seems worth less than the paper said warranty is printed on...
What would you guys do? I want to try to work it out locally, without having to deal with VWoC if possible... but am not averse to escalating if required.
Couple questions.
