rowl
OK, I unfotunately have the worst case scenario. I got the head off my timing belt disaster and the head is a gonner and the last piston (furthest from the timing belt, I assume #4) is beat to HE##! The exhaust valve was imbedded in the recessed portion of the piston. The good news, if there is any, is that not a single one of the other pistons or valves appear to have been touched. I think it jumped time, but now I just wonder if a valve didn't just break.
On to my real question; I have seen some discussion on this topic, but cannot find a lot; can I get some opinions on whether I should just get a longblock, or should I consider getting a head and replacing only the bad piston and rod. I assume the rod will be bent due to the condition of the piston. I have seen some say replace the bad parts and drive on.
By the way, I have a 2000 Jetta GL TDI, Manual Trans., 78,000 mi. It is my son's car and he thinks he is about to die because he is away at college and NO RIDE! There are worse things, he will survive......Thanks for any advice I can get and I am sure I will have more questions as I decide what to do and proceed to get him back on the road.
