Ok so quick once over. I'm at the near end of my brain with this swap.
2003 gas 2.0 wagon with a pd150 in. Customer brings it in because of no boost. It runs, it drives, just no boost. 100% limp mode all the time. While looking through all wiring, trying a few combinations, it still runs and drives just not boost.
I take the battery out to test some wires. 2 weeks later I get back to the car. Put the battery back in and...... crank no start.
Check fuses, all good. Check timing, good. Check crank sensor, acting funny so replaced, still no start
Cam sensor test good. Lift pump good. Tandem pump seemed a little low on pressure when cranking so swapped a good known one on. Still crank no start. Also, have tried a few different ecu's.
So I guess I'll start with this question? Is there something I am missing from staring at this thing to long.
Thanks if anyone can help. Starting again on in soon.
