Caswell239
Hey all, for some reason my ecm will not allow the injectors to fire causing my no start. Brand new to using vcds, so not sure where to look to help. Only code I have is 19464 cam sensor signal out of range. Try unplugging and no difference. Took voltage readings right from the injectors, and have .03v on power side. Have continuity in all injector power wires and the grounds to the ecm. Not sure where to go next. Any help is greatly appreciated,
