D-Cup
- Joined
- Jul 22, 2017
- Location
- San Antonio TX
- TDI
- 2010 Jetta TDI Cup Edition, 2003 Jetta GLS, 2000 Jetta GLS, 2012 JSW
Ok, so I've searched high and low, both here and VW Vortex, and can't find quite the info I'm looking for.
What I have: 2010 Jetta TDI Cup Edition (GLI suspension, 18" wheels, 225/40 R18 tires)
I'm currently at 163k miles, planning ahead to do a complete suspension refresh at 200k miles because my back end sags with a full tank of fuel, and really sags with 2 kids and camping gear. Finances dictate that I plan ahead and get best bang for the buck. Would like new suspension to last for the next 200k miles if at all possible. (Next 200k will probably look very similar to my first 200k)
What I'm looking for: Slight lift is preferable, stock ride height at a minimum. More firm handling is preferable without being too jarring.
-I've looked at doing Tiguan springs & Koni FSDs, but while I really like the look of that height on the JSW I haven't liked the look on the Jetta sedans that I've seen with those springs. (Although that blue Golf R on the lifting JSW forum looks super bada** and would LOVE to transfer that to my Jetta so if anyone has a link to that guy's build let me know as I haven't been able to find it.)
-Bilstein HDs claim a 1/2" lift over stock. I can only assume this is compared to "normal" stock suspension. Does anyone know how this alleged amount of lift compares to the GLI suspension? Also, I'm concerned about the ride being a little too stiff.
-Koni FSDs with OEM springs looks like my most inviting option so far. Is there any lift to be had with this setup compared to GLI OEM suspension?
-I will be due for new tires at 200k as well. I'm looking at going larger sidewall. I have found plenty of folks saying that 225/45 R18 fit just fine. I have found enough posts to "know" that 225/55 DO NOT fit and WILL rub. I have found 1 post from 1 person here on tdiclub that 225/50 R18 does fit with no rubbing on his JSW. Can anyone chime in on this size tire? It looks real inviting but don't want to buy something that doesn't fit.
I will probably just use an air lift to level out ride if I ever start towing a small trailer, so towing is not a primary goal/concern for spring selection.
I know this is more of a vortex question but everyone over there seems to be stuck on lowering cars and winning pissing matches vs the helpful environment on this forum.
Thank you in advance for your input.
