GIDDY_UP_GO
Ok, so my car is an 04 TDI Jetta with a 5 speed MT. I recently replaced the starter and it has a new battery. Drove the car all day today, started no problem. Final destination, depressed the clutch and turned the key and nothing!
Ended up push starting the car and it fired right off.
So, I am thinking it is the switch that when you press the clutch. Cause the car will not start without depressing the clutch and this is my 1st thought of why its not cranking over. I don't get a click or any other typical starter problem, so this is why I think its a clutch switch.
Anyone have any advice? Is there a way to bypass this switch?
Comments and ideas welcomed!
