I have a 2002 Beetle. There is no keyed lock for the hatch. The door switch and the key farb will not open it. May question is, is there a way to get the thing opened without crawling through the backseat, pulling of the boot, and opening it. With a screwdriver? Could it be fitted with the latch from an older model? At this point, I don't care if I have to drill a hole,if I could use a key. Or could I just pull the battery cable to reset the computer? Any help would be appreciated. Thanks, Joe
