thundershorts
- Joined
- Jul 15, 2010
- Location
- west chester pa
- TDI
- 2015 passat tdi sel premium 2015 golf s tdi gls tdi b5.5, 2002 eurovan,Peugeot 505 td,Citroen cx25 prestige
my 2015 new 82 mile passat tdi sel had a subframe misalignment causing castor and camber problems. dealer quoted 4000 plus to fix. Had fixed by a great VW master tech for 3900 less. Apparently this is caused by the improper chaining down on the transporter. According to him its fairly common. Now with it setup with zero toe front and rear, .01 degrees negative rear camber, its great to drive. Conti tires. You might never know you have this problem unless you put on te alignment rack because of factory toe settings, untill you have ruined a perfectally good set of tires. My 56k passal sel that I'm selling back to VW has a good 30k miles left on the conti tires because I did this setup on it.
