Extended Emissions Warranty
Coverage
For the following Volkswagen 2.0 L TDI engine vehicles repaired by
the emissions modification recall, a warranty extension is applicable
as defined below.
2015 MY Beetle with engine code CVCA
2015 MY Beetle Convertible with engine code CVCA
2015 MY Golf with engine code CRUA
2015 MY Golf SportWagen with engine code CRUA
2015 MY Jetta with engine code CVCA
2015 MY Passat with engine code CVCA
Warranty Period
The warranty period for the “Extended Emissions Warranty” limited
warranty extension shall be the greater of:
11 years or 162,000 miles, whichever occurs first, from
the vehicle’s original in-service date; OR
5 years or 60,000 miles, whichever occurs first, from the
date and mileage of Phase 1 of the emissions modification.
At the time of the subsequent Phase 2 modification, the
extended warranty will be honored for 5 years or 60,000
miles, whichever occurs first, from the date and mileage of
the completion of Phase 2.
The vehicle’s original in-service date is defined as the date the vehicle
was delivered to either the original purchaser or the original lessee; or
if the vehicle was first placed in service as a “demonstrator” or
“company” car, on the date such vehicle was first placed in service.
10
Parts Covered Under Extended Warranty
The emissions system warranty shall cover the following parts or
systems:
The entire exhaust after treatment system, including the Diesel
Oxidation Catalyst, the Diesel Particulate Filter, the Selective
Catalytic Reduction converter, the dosing injector and other Diesel
Exhaust Fluid system components, the exhaust flap, and all sensors
and actuators
The entire fuel system, including fuel pumps, high pressure fuel rail,
fuel injectors, vibration damper, pressure control valve and all
sensors and actuators
The EGR system, including EGR valves, EGR cooler, EGR filter, EGR
temperature sensor, all related hoses and pipes, and all sensors
and actuators
The turbocharger, including the turbocharger damper
The On-Board Diagnostic (OBD) system, including SCR DEF quality
sensor, and any malfunctions detected by the OBD systems other
than those related to the transmission.
Additionally, the engine long block warranty shall cover the engine
sub-assembly that consists of the assembled block, crankshaft, cylinder
head, camshaft, and valve train
The extended emissions warranty includes parts, labor, and applicable
taxes. The extended emissions warranty shall not void or supersede any
existing warranty.
Conflicts concerning the warranty are to be resolved
in favor of the consumer.
More information about your extended emissions warranty coverage is
available at
www.vwdiesellookup.com and in the customer letter we
sent to you in January 2017.
