Double Dee
2004 Golf GLS TDI BEW
Where is this sensor located?
Well kinda. The crank sensor does sense speed, but is indexed to crankshaft position in relation to TDC.FWIW The camshaft has a position sensor; the crankshaft has a engine speed sensor.
When you look in Vagcom at engine speed; this is the sensor that tells the ECU that piece of information. When you are at idle speed; this input (engine speed) is what the ECU will adjust the fuel injection to maintain the desired idle RPM. If this signal isn't there (or if it faulters intermittently like mine did); the car just turns off as if you did it with the key. I'm not so sure if this sensor on the BEW engines reports anything having to do with crankshaft position. The camshaft has a position sensor & the setup for knowing camshaft position is quite different.Well kinda. The crank sensor does sense speed, but is indexed to crankshaft position in relation to TDC.
I think your point is that what stroke you are on can't be determined from the crank sensor.
