So far, no consistent issues with my MIB system. We connect an iPhone to the cable and most of the time it wants to default to iTunes songs on the phone. If I then choose a podcast or streaming app, the unit will eventually play that.
Bluetooth with the Android has been pretty flawless until yesterday. I was able to use the system to go through my calls and select someone from the list, then make the call. Once that started, there was no audio through the car, just the phone directly. As if the Bluetooth was only half working.
I hung up. The person later phoned me back and I answered it using the car's system, but nothing through the audio. Weird.
I later tried to stream to it from the phone and it worked. I also made a call and that was normal again. Later still, on my way home, it did not immediately connect to the phone/bluetooth as it usually does. It tried, then gave some error on the MFD, and the infotainment system flickered and finally came to life.
This may be a fluke, I don't know. I hope it was just that and not a bigger problem.
