falk_ben
Hi all
Just looking for advise on my next step of tune.
Running a second A5 2260vk and was going to freshen it up with a bearing and seal mellett rebuild. Just was thinking of stepping up to a 2565 with gen 2 compressor? I know I'd have to get my housings profiled but it would be a good time to do it.
Turbo OK at the moment but not sure on the history. Not smoky and holds boost well.
Can't afford a Darkside 2872 which would be the icing on the cake.
What are the pros and cons. Looking for a nice 320-330hp once i covert to bkd ecu 120% injectors (current bmn Siemens)
What are the flaws with 2260vk hybrids, wheel matching and extended tips etc? Is there a ideal ratio between size or turbine and compressor?
Any one had good results?
