puffsmokeonya
hey iam also looking for the EGR block off. iam gonna buy one. and i would also like pictures of the install. (the how to i guess) i think a fuel block off plate would work to.
My stock clutch is holding it great, if i floor it from about a 15mph roll i can usually break the tires loose. I plan finding it's limit.TdiAvenger said:i had fun with one of these back in 2006. A little too much fun. My "little black box"(i set it up in a box with a knob on it to adjust the resistance) plus my nozzles were too much for my stock clutch
Easy killer, this is a mod is kind of like going out in the middle of a field during a storm with a metal bar in your hand. Everything is set for bad things to happen, but it may or may not happen. Dumping in more fuel skyrockets the boost and causes higher EGTs.UUUmmmmm, any mod could "potentially" do that.
when i had mine turned all the way down(or up if you like) and with the combination of my nozzles.....well lets just say i nicknamed it my "smoke box"RDC98tdi said:That's why you put a switch on it, so you can turn it off, keeping the engine, exhaust manifold and such from wearing out too soon, and keeping your MPG's in the 40's. I like using it only from red lights and when passing someone. Im thinking of knocking the resistance down on each setting to about 1100 and 650 ohms. 1300 is barely noticeable, and 800 hardly makes is smoke even with WOT.
That's what you get with big nozzles and small turbine.NB_TDi said:That picture is pure win.
Must have a really free flowing exhaust on that car - look how fast it comes outDakta said:smoke box?
I had one of thems once. Sadly this was before rover decided to go for the vp37, so all adjustments were with a screwdriver, not fancy resistors
Oops.evanbatterman said:So im pretty sure ****ed up. i cut wires 2&3 and tried to get them hooked up to the pot, and ended cuting out more than I should have so now I cant even put my line back together like they should have been
How about NO.Ban the EVRY already
Day is done. Five tests, back to back, all pulls within 15 minutes.I picked up some used '98+ A3 chips for $70 that may or may not work in my '97 A3. Here's to hoping they do.
There's a dyno day coming up where I intend to test both against stock.
What would you say are the chances that the chip will make 10 times the increase in power of my bodged modifications?
