fase2000TDI
Friend of mine bought his daughter a 2011 Jetta. She was so appreciative she decided to go over a speed bump in excess of the suspensions capabilities, or likely drove over a median. Either way, she claims she "just went over a speed bump". The car was then driven (upon advice of a dealership) over 100 miles round trip to the dealership where the car was purchased, at which point it was found that the intercooler had been broken - an area of about 2" diameter hole as well as the radiator support. This would obviously not be covered under warranty.
Vehicle was towed to a body shop at that point where said friend is friends w/ the owner. A new VW DPF was put on due to an excessive soot accumulation code. (likely relating due to driving with no boost, excessive soot clogged the DPF). I was asked to clear the DPF code after the new DPF was put on, but as soon as I clear it the code returns. The code I get is:
1 Fault Found:
009315 - Diesel Particle Filter
P2463 - 000 - Excessive Soot Accumulation - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Mileage: 27703 km
Time Indication: 0
Date: 2019.14.26
Time: 16:07:46
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
Pressure: 3 mbar
Hex Value: 0xFF02
Temperature: 84.0°C
(no units): 45.9
Mileage: 310 km
No sensors were replaced. Those of you with DPF replacement experience, what do you suggest? This isn't a car I'm servicing - I'm just trying to help a friend in need. I'm at a loss of what should be done - other than sell the car and give the daughter a car deserving of her poor driving habits. Perhaps a Geo Metro or a Chevrolet Prism.
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 27703 km
Time Indication: 0
Date: 2019.14.26
Time: 16:07:46
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
Pressure: 3 mbar
Hex Value: 0xFF02
Temperature: 84.0°C
(no units): 45.9
Mileage: 310 km
