thermo
Hi everyone,
At almost 130,000 miles on my 2000 Jetta TDI (ALH), I am now getting an
intermitant signal from the left rear wheel speed sensor. This is causing the ABS light to come on. I used the VAG scope and verified that the signal is dropping out on this wheel.
The problem is that I cannot remove the wiring clip from the sensor and I cannot remove the sensor from the hub.
Does anyone have any tips on how to remove the clip and the sensor?
I thought about removing the brake disc and seeing if I could use a punch to knock it out from the fron/outside.
Thanks!
Thanks!
