Old August 23rd, 2012, 14:40   #331
ramb02
Module installed in our car yesterday. We have the navigation system, so as chetstash said, I am now able to use the phone button on the radio to access the phonebook, dial numbers, etc. I also have the voice command functions to dial numbers by voice command. As mentioned earlier, the overhead light no longer functions to indicate bluetooth linkage, but if I need to know, I'm sure I could just hit the phone button on the nav/radio unit. Overall, it is working quite well.
ramb02 is offline   Reply With Quote
Old August 23rd, 2012, 16:45   #332
Mr. Timewise
Mr. Timewise's Avatar
Keep in mind that VW disabled the overhead BT LED light in all vehicles as of 2011. They had received many complaints that the LED light was a distraction. For some people the light reflected in the rear view mirror when the mirror was tilted up for night driving.
Mr. Timewise is offline   Reply With Quote
Old August 23rd, 2012, 23:27   #333
ramb02
I'm fine with the light being gone. I don't think I'll miss it.
Old August 24th, 2012, 08:08   #334
gmcjetpilot
gmcjetpilot's Avatar
I have an RCD510. If I buy the 9W7 unit will I be able to display the phone book on the MFD/MCI. Thanks
gmcjetpilot is offline   Reply With Quote
Old August 24th, 2012, 09:27   #335
Mr. Timewise
Does your MFD presently show a overhead line drawing view of the car when a door is open?
If so, then you must have a "high-line" MFD and the MFD should show the phonebook. The presence or absence of the RCD-510 in the car is irrelevant as the 9W7 and MFD can communicate via the CANbus directly.
Old August 24th, 2012, 17:02   #336
cowpotty
I got the bluetooth module upgrade done today. I get voice assistance on calls but phone book, etc. will not come up on the small screen display. Dealership went through the process twice and still does not work. Any idea what might be the problem.
cowpotty is offline   Reply With Quote
Old August 25th, 2012, 09:19   #337
Mr. Timewise
If you have a "low-line" small screen MFD, it is not capable of displaying anything other than what you have always seen. Please read this post:
http://forums.vwvortex.com/showthrea...1#post68258183
2010 Jetta SE 2.5L Tiptronic Salsa Red | 9W7 Bluetooth | RNS-510 | Homelink sun visor | Extendable passenger's sun visor | MFSW w/ paddle shifters | Hi-line SWCM | Hi-Line MFD+ cluster | Auto-dimming mirror w/ compass | Trunk release switch in grab handle | Silver lens tail lights | Front & Rear door warning/puddle lights | Walnut interior trim
Old August 25th, 2012, 11:34   #338
gmcjetpilot
Yes it does, so that is good news. I am wondering how hard to upgrade to RNS-510, if I can buy a used one and slide it in?
Not 100% but from previous posts the Settlement unit does not display the phonebook on the MFD high-line or not. That is where the RNS-510 comes in, you can display phone book there via the radio. For us with RCD-510's the settlement unit gives you voice calling, that is all. That why I am passing on my upgrade unit, but considering a 9W7 out of pocket.
Old August 25th, 2012, 14:05   #339
Mr. Timewise
...I am passing on my upgrade unit, but considering a 9W7 out of pocket.
Smart move.
Old August 26th, 2012, 03:50   #340
ksing44
Just so you know, the newest version of the RCD510 has a phone button and displays the phone information. It also has HD radio. I'm just thinking it might cost much less to get the new RCD510, rather than the RNS510.
2010 Golf TDI - (BGM), 4-Dr, 6-M, Sunroof, Xenon, Dynaudio, Nav (RNS-510), Euro light switch, 9W7 BT, R Tinted LED Tail Lights, Monte Carlo 17" x 7.5" ET47 Wheels, 235/45/17 Tires, P3Cars Digital Interface, Sonniboy sunshades, CP3 HPFP: 11/8/2016 @139,848 miles, The Fix: 9/27/17 @153,289 miles
Flickr slideshow
ksing44 is offline   Reply With Quote
Old August 30th, 2012, 17:56   #341
jeffjeja
TDI(s): 2010 JSW TDI
Default Frustrations with "upgrade" system
Have had the new module for about a week now and am really feeling the absence of the visual phonebook in the display. There are some voice prompts - and basic ones at that - that the system does not seem to recognize. When I ask to call "Home" I get a non-recognition response though it is an entry in my contacts, and when I request a call to "Voicemail," when it finally does recognize the request the system pronounces it something along the lines of "voy-a-mail." Other names in my contacts do not seem to pose a problem; one would think home and voicemail would be programmed in to be recognized. Of course, being able to scroll through a written list (as should be available) would mitigate the issue a good deal.
jeffjeja is offline   Reply With Quote
Old August 30th, 2012, 19:22   #342
MondoTech
I just bought a used 2010 TDI, can I still get the module replaced with the 9w7?
MondoTech is offline   Reply With Quote
Old August 30th, 2012, 19:57   #343
kjclow
You can purchase a 9w7 module but probably not get reimbursed through the lawsuit.
Old August 30th, 2012, 20:01   #344
ESFlash
FWIW -- I decided against having the dealer install the new upgraded BT module. Not enough positives to make it worthwhile for me
This is a based on:
1) reading what other users discovered about this part and how it worked out of them.
2) the realization that in all likelihood I'll never see a caller ID or have a phone book display on anything other than my fone -- I have the basic RCD-510 and not a RNS-510 (which from all reports can display fonebook).
3) not needing voice initiated call making from the dash (as I have it on the fone already). I don't initiate all that many calls anyway; receive calls yes.....and the existing system is good for that, so no need to "upgrade"
I also kind of dig that little green status light and don't necessarily want to give that up. I realize there's a display that shows connection, but I like the simplicity of the light and it's not bothersome day or nite.
So I guess I'll call the dealer and tell them they can give my part to someone else.
ESFlash is offline   Reply With Quote
Old August 31st, 2012, 00:01   #345
gmcjetpilot
[QUOTE=MondoTech;3918259]I just bought a used 2010 TDI, can I still get the module replaced with the 9w7?[QUOTE]
1) The time to apply for a 9W7 reimbursement is over.
2) The time to applying for what is called the "settlement unit" I also think is a ship that has sailed.
3) To be eligible you have to testify one of the prime reasons you bought the car was because of "hands free" BT. Not sure if you have to be the first original owner or not.
4) If you don't have a RNS510 or late model RCD510 radio with the phone button, the "settlement unit" apparently will not display the phone book on the MFD/MFI, so all you get is voice commands, "CALL MOM"....
5) The stock system works well for incoming calls.
6) You can buy a new 9W7 unit for under $300, delevered to the door. For me a 9w7 will get me the phone directory on the MFD (but you need a high line MFD, which I have). As I said in #4, the settelment unit does not give you phone book on MFD regardless of radio you have.....
A4 Jetta not included in Water Ingress Class Settlement ZipiTDi VW MKIV-A4 TDIs (VE and PD) 5 September 23rd, 2011 11:38
MK6 & Audi A3 owners rejoice! The Dieselgeek MK5/MK6 Panzer fits your car perfectly! corrado tdi Vendor & GroupBuy items for sale 0 April 22nd, 2010 17:31
Class Action on Keys ... Joe_Meehan General VW Discussion 24 August 17th, 2008 17:06
Class Action Suit. whitedog General Automotive 38 April 23rd, 2005 21:37
MAF class-action SoCalJames VW MKIV-A4 TDIs (VE and PD) 3 August 30th, 2003 04:35
Page generated in 0.11730 seconds with 13 queries
[Output: 133.08 Kb. compressed to 111.47 Kb. by saving 21.60 Kb. (16.23%)]
