supervanno
SOLVED - T5 1.9tdi Won't start after rebuild - A real prize if you diagnose it
Hello and thanks for reading. SOLVED - crankshaft position sensor ring out out of position by about 90 degrees.
If someone is able to diagnose the problem, I'll make and send them something small but cool, for free. I promise. No P&P, no money, nothing.
And now the problem. Did a full engine rebuild and it won't start.
I have a VW T5 1.9tdi PD. it's a BRS engine code 105(?) bhp I think, maybe (102?), the Van is 2008.
I bought it with high miles (300k) and it transpired to need an engine rebuild. The crank was knocking.
Engine removed and stripped shows me the main bearings have collapsed, and the bearing caps and block are damaged.
I got a replacement engine, from a Seat Toledo, 2008, a BJB engine code, which is 105bhp.
I stripped the replacement engine to check it was good inside and found one main bearing shell with a small fragment missing, so it was worth doing the rebuild.
I then rebuilt the engine using:
Sump & oil pickup from the BRS (van) engine
Crank/rods/pistons/cast iron block from BJB (toledo) engine
New head gasket of course and new stretch bolts throughout.
Complete Head from the BRS (inc cam, tappets & injectors)
The head was disassembled and rebuilt using new bolts, but existing shells.
I adjusted the injectors as per the correct procedure, one was 45 degrees turn out.
But it won't start.
I've checked:
Timing set with indexing tools
Swapped crank-shaft-timing-pulley from the BRS and BJB engines, as they're different (BRS pulley is slightly oval)
Changed Camshaft position sensor
Checked cam position sensor wiring continuity to the ecu
Checked lift pump - fine
Bled fuel by vacuum into the filter
Checked battery
Observed all instrument lights correct
Tried to start with crankshaft or camshaft position sensor disconnected
Started it on easy-start
Towed it for half a mile at 40mph at 4000rpm
Tried adjusting the camshaft pulley slightly forwards and backwards, deliberately setting it just slightly wrong.
Checked crankshaft position sensor positions on both engines (they match)
Checked part numbers of flywheels for both engines (they match)
Checked the stop valve in the throttle body is open
Checked wiring to the injectors - not continunity, just visual inspection
Verified fuel pump working and sending fuel on the return line to the filter.
(If I've left anything out I'll add it...)
I had a diagnostic computer on it before I used the indexing tool - it threw up "implausible position". But the position was very very close to be exact - I'm not sure what tolerance there is on that. Anyway, it's definitely correct now.
So right now I'm out of options.
It has air, fuel, compression (not checked but it sounds normal, and no reason to assume it's bad)
The computer won't inject diesel.
There's no smoke of any colour, no unburnt white diesel, no smell of diesel.
The diagnostic computer said 0ml injected.
We're stumped. And I can no longer give the van any more time. It took much longer than expected and I'm out of time.
So if you can diagnose the problem, I'll make and send you a gift, I make steel things, blacksmithing, fabrication and art and I write.... As gratitude for your attention. But you'll just have to trust me that I'll do it. But I will.
In the event a few people get the answer, I'll make a few things. Keep your expectations low, then you won't be disappointed!
Thank you in advance.
But it won't start.
I've checked:
Checked battery
