D
dlm308rem
Guest
Needed.
If you have an 06 Jetta TDI with DSG and could send me a picture of your fuse panel on the left side (drivers side) of the dash, I would be most appreciative.
You may send pictures to danm@cityofws.org or 336-577-8150, or post them here.
I was checking fuses this weekend and now have a flashing PRNDS, cannot get the car out of park and the key will not release, plus the car will start only after about 15 seconds of holding the key in the start position. I think I may not have gotten one of the fuses back in the right slots. Should have taken a pic before but did not.
A couple of codes I am now getting are:
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 043 HW: 02E 927 770 AE
Component: GSG DSG 070 1126
Revision: 04507000 Serial number: 00000512070520
Coding: 0000020
Shop #: WSC 00066 000 00000
VCID: 51A28248C853DDB689-8004
3 Faults Found:
28775 - No Communication with Gear Selector Module
U0103 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 255
Reset counter: 40
Mileage: 246095 km
Time Indication: 0
00194 - Ignition Key Removal Lock
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Reset counter: 1
Mileage: 246095 km
Time Indication: 0
U0103 - 004 -
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Reset counter: 0
Mileage: 246095 km
Time Indication: 0
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 034 0070
Coding: 0010021
VCID: 78F41FEC0B69ACFE6E-802C
1 Fault Found:
02413 - Switch for Selector Lever Position P Lock (F319)
Thanks for your assistance.
Fred
Coding: 0000020
3 Faults Found:
U0103 - 000 -
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 246095 km
Time Indication: 0
Freeze Frame:
Fault Priority: 0
Reset counter: 1
Mileage: 246095 km
Time Indication: 0
U0103 - 004 -
Freeze Frame:
Fault Priority: 0
Reset counter: 0
Mileage: 246095 km
Time Indication: 0
Coding: 0010021
1 Fault Found:
Fred
