Old October 4th, 2003, 19:35   #1
Occams_Razor
Occams_Razor's Avatar
Default Hella Headlight Washer Retrofit Kit on a Jetta
Hi All,
Since the only installation instructions are from Roger Moore for the Golf I deceided to post instructions specific to the Jetta.
Step 1:
Open the hood. [img]/images/graemlins/grin.gif[/img]
Remove the grill. The grill is held on its corners by hooks that snap into the bumper cover. The hooks go where the orange circles indicate in the following picture.
Lifting the edge of the grill will allow you to unsnap it and pull the top towards you. Don't pull too far as you still have to disconnect the hood release handle; like so:
Once the hood release handle is removed you can pull off the grill .
Now proceed to remove the bumper. The Jetta bumper is held by 4 T25 torx screws inside the frt edge of each fender well. (Don't forget to remove the side markers! Push in on the frt edge until it goes into the bumper and pull the rear edge off. No need to pry!)
5 T30 torx bolts are located underneath the grill.
2 T30 torx bolts inside the bumper air intakes. Sorry no picture. To take the plastic intake covers off just pinch on the two slots on each end. You'll figure it out! [img]/images/graemlins/laugh.gif[/img]
Once all the bumper bolts are off you can pull the bumper to the frt and off. Make sure to place it on something soft, especially the pointed corners at the rear, to avoid scratching the paint. Don't ask how I know this... [img]/images/graemlins/rolleyes.gif[/img]
You should now have this staring at you:
Here is the headlight washer kit; Hella Golf IV headlamp washer retrofit kit #8WS 008 558-001,(Yes you need the Golf IV kit. Hella does not make a kit specifically for the Jetta/Bora.), that Chad is procuring from Germany.
Everything in the picture is included except for relay 192, (if you are going to ever use the rain sensor gizmo in your windshield), or relay 603, (4B0 955 531 E relay with headlight washers but no rain sensor gizmo), the Bora washer nozzles and the Bora washer nozzle covers. The kit includes the washer nozzles and covers from a Golf which do not work with the Jetta bumper.
Just to clarify. To complete the kit for a Jetta you will need in ADDITION TO THE KIT the following parts from Germany, (unless John at IMPEX relents and deciedes to bring some in. Last time I asked they said the part numbers was obsolete! [img]/images/graemlins/mad.gif[/img]):
1J5 955 109A Bora Headlight Washer Cover, Left
1J5 955 110A Bora Headlight Washer Cover, Right
1J5 955 103 Bora Headlight Washer Jet Carrier w/ Jet, Left
1J5 955 104 Bora Headlight Washer Jet Carrier w/ Jet, Right
If you want to wire the kit the same as the factory installation, (Downside of the hella retrofit kit is that your headlights get sprayed everytime you clean your windshield. The OEM install only sprays your headlights when the lights are ON and every 4th time you squirt the windshield. The Hella way, everytime, you'll go through fluid like crazy.).
You will also need to replace the stock windshield wiper relay, (usually Relay 377), with:
1J0 955 531 "Relay 192", (if you have any plans to use the rain sensor gizmo with your windshield. If you don't have the rain sensor you will lose the intermittant function of your wipers with the "192" relay.), or;
4B0 955 531 E "Relay 603", (this relay is the one for headlight washers with no rain sensor.)
Now we come to the biggest headache. I have confirmed that you do need a euro rebar, (even if you have a wagon), unless you can get a used one from a US MY2001 Jetta wagon. (I have a 2003 wagon and it has the same rebar as the sedan.. Made in Mexico no less!) The Euro Rebar is needed to mount the washer assemblies.
Correct Part Number for the Euro Rebar = 1J0 805 551 <font color="red">E</font>
NOTE: It seems that the VW warehouse has the C rebar, (US), as the replacement for the E euro rebar in their computer and it doesn't matter what number you order you will be getting the C if you are in the US.
John at IMPEX will be trying to get some of the correct ones from Germany but it might take awhile. If you are interested let IMPEX know that you want the E rebar with the headlight washer mounts because if you order it from the web form it will default to what VW says and you will receive the wrong one! (Don't ask me how I know this..) [img]/images/graemlins/mad.gif[/img]
You DO NOT need the Euro bumper cover for the Jetta/Bora. The front bumper covers are almost identical. The only difference is that the euro bumper cover has a set of dimples on the inside face to help guide where you need to cut the hole for the nozzles. The US bumper does not have the dimples. (Unless you have a wagon like mine, (made in Germany), that contrary to popular believe DID have the dimples!).
ETKA actually tells you that if you need the euro cover for a car with headlight washers it will need to be shop modified, hence the dimples.
Remove your headlamp assemblies. 4 T25 torx screws.
Siphon the fluid out of the 3 ltr. reservoir using the long supplied hole in the kit into a clean container.
Remove the stock 3 ltr. reservior. Remove the tank by loosening up 2 10mm nuts and one 10mm screw. It is held with a plastic nut found behind the bottle bolted to the fender and right in front of the bottle on the plate above the intercooler.
Disconnect the pump wire and fluid level sensor wire. If you have a wagon you will also find some cool little disconnects for the water hoses that go back to the tail gate.
Prepare the new tank.
Install the filter in the neck and cap;
Install the headlight washer pump with the new grommet from the kit in the frt hole of the bottle;
Install the old pump using the old grommet in the back hole of the bottle;
If your tank has the level sensor hole install the old level sensor using the old grommet.
If your tank, (like mine), doesn't have the hole for the level sensor don't despair! A hole can be drilled in the tank without too much trouble using a 1" Forstner Bit.
NOTE: When you drill the hole, (best done on a drill press after measuring 27 times to make sure you have it in the exact same relative position as the original bottle), you may find that the sensor fits in very tightly or doesn't want to go in at all. DO NOT SAND THE HOLE TO MAKE IT BIGGER! The reason it is not going in correctly is because the hole has a ridge formed on the inside from the drilling. Take a knife and scrape the ridge off and the sensor should fit in nice and snug and not leak. (Or you can do what I did. Sand it with a drum in the drill press. Make it oversize and have to use epoxy to help the grommet seal after all the water leaked out after installing the darn thing!) [img]/images/graemlins/rolleyes.gif[/img]
Once the bottle is ready you have to do what SVTWEB best described as "Stuffing 150 pds of sh*t into a 50 pd bag" or words to that effect. (Actually Eric is wrong. It is more like having to stuff 200 pds of sh*t into a 25 pd bag but I digress.) [img]/images/graemlins/rolleyes.gif[/img]
To make this part easier, (and so you can learn from my mistakes), I suggest you:
1) Remove the fuel filter, (you don't have to disconnect it. Unbolt it and lift it out of the way.),
2) Remove the upper and lower intercooler hoses and the intercooler.
3) Remove the wire loom guide/support from the right side, (looking from above), of the ledge where the washer bottle will now live. The new bottle is bigger in that area and the loom guide/support interferes.
Once you have those parts off it is still a pain but at least you will be able to make yourself believe that their actually is enough room to install the !@#$%^&amp;* bottle.
Once the bottle is installed connect everthing back in the reverse of the removal. [img]/images/graemlins/grin.gif[/img]
It should look like this when you are done:
Once the bottle is installed you can proceed to the removal of your US rebar and replacement with the "correct" Euro rebar.
I think there are 2 bolts on the ends and various torx bolts/screws on the bottom and in the middle. (Didn't take a picture so I can't remember exactly.)
It has been brought to my attention that the support for the lock carrier is different to correctly support the euro rebar. The correct part number for the support for the lock carrier is 1J0 805 567.
(I didn't bother getting the new lock carrier support so didn't originally give the part number.)
For some strange reason IMPEX shows 1J0 805 567 as being equivalant to 1J0 805 567 B, (which is the US lock carrier support), with 2 different prices. I think it is the same situation as the euro rebar. VWOA is crossindexing the euro number to its american counterpart. Buyer beware!
Once the Euro rebar is installed install the washer pumps.
They are left and right, (and are marked as such on the body of the pump), so don't mix them up!
BTW The bottom of the pumps rotate so don't freak out if the outlets aren't pointing where they should. [img]/images/graemlins/eek.gif[/img] You can turn them to the correct orientation. [img]/images/graemlins/grin.gif[/img]
With the nozzles installed it is all a matter of running the hose to each nozzle. It should look like this when done.
and
The rest of the installation is the cutting of the bumper but I don't have any pictures.
My bumper, (2003 wagon), had the dimples on the bottom edge so I connected the dots with a Sharpie and then I used a 1 3/8" Forsnter bit to drill out the initial hole and then used the Roger Moore drill method to open the oval up. I connected the drill holes with a cut off wheel in a Dremel and then I used a 1" sanding drum, by hand, to get the final shape.
Make sure you sand a little and measure the fit of the washer covers as you go until they just fit. They should fit without too much side to side clearance so they will always fall back to the same place after spraying your headlights.
Once the cutting is done the installation of the bumper and grill is the reverse of the removal! [img]/images/graemlins/grin.gif[/img]
NOTE: The Euro rebar DOES NOT USE THE FOAM from the US rebar. It doesn't fit and the Euro cars don't use foam at all. Nyet, Nine, Nada, Nothing as SVTWEB would say.
If you are going to use the Hella wiring please go to Roger Moores explanation for details. My kit did not contain the instructions and I didn't use the Hella wiring anyway..
I wired my washers with Chris Kennedys instructions except for one minor detail that I have corrected here:
[ QUOTE ]
Now how to wire it in:
Wires you'll need;
(1) 000 979 133 (A)
(1) 000 979 212
(1) 000 979 225 (A)
Some 2.5mm wire (14 gauge?)
You can download the wiring diagrams for the headlight washer system here:
http://pics.tdiclub.com/members/Kenn...amp_washer.pdf
As you can see, you only need to run 3 wires.
You'll need to run a 000 979 133 from pin 11 of T/17 (headlight switch to pin 9 of T18a connector (it's that relay plate the control module plugs into).
Run on wire from a switched/fused power soure (fuse 33 in the fuse box to be correct) to pin 15 of the T18a connector. You'll need one 000 979 212 wire, cut it in half. That 's the wire connector you'll need. Take the other end of the wire and plug it into pin <font color="red"> 6 </font> of the T18a connector and run it outside the firewall to the washer pump. Get a 000 979 225 wire and cut it half. Splice a one half into the wire coming from the firewall and plug it the #2 pin on the pump connector. Take the other half of the 000 979 225, plug it into pin one of the pump connector and run it to ground.
The hardest part of this whole process is taking apart the T18a relay plate. I destroyed mine removing the "pink block" for the back. Once destroyed, you can order another, seperate the pink block with great care, extract the existing wires from the destroyed connector and put them in the new connector. It's a real PIA, but I'm anal about my wiring and sticking to OEM convention.
PN for the T18a relay plate: 4A0937529
Also, little hint... While you have the relay plate apart plug a wire into pin 10 and 14 before you put the pink block back together. This way you won't have to break the thing again should you ever decide to do the rain sensor/antidazzle mirror. That's where the rain sensor gets connects.
[/ QUOTE ]
The relay plate is the hardest part but using an AOL CD box you can get around the frustration of destroying it and having to buy a new one.
The explanation on what you need to do is here:
Relay Plate Seperation
Once all is said and done the installation looks and works very well and isn't extremly hard to do.
I am sorry I don't have a picture of the washers at work but I can tell you they look dang cool when they do! [img]/images/graemlins/cool.gif[/img]
BTW Most of the pictures are mine but I did "borrow" some of Litos since my digital camera "ate" the ones I took.
Have fun! [img]/images/graemlins/grin.gif[/img]
Occams_Razor is offline   Reply With Quote
Old October 4th, 2003, 21:17   #2
tongsli
OC,
Nice Job!! Thanks for the instructions. For the Golf, don't they need the rebar and bumper??
I'm wondering now if that kit is really worth it? The 5.5L tank can be sourced here in the US with the sensor hole.
All of the hose connections can be sourced from Audi. And probably the hose as well.
I'm not sure about the pumps. But, the covers and nozzels definately need to be sourced from Germany.
Well, maybe it's still cheaper now that I run through all the parts.
Any thoughts?
L
PS. The stock configuration doesn't do the 4th spray thing. It will spray if you hold the wiper stalk. It's possible to spritz the windshield without activating them with the lights on.
tongsli is offline   Reply With Quote
Old October 5th, 2003, 13:40   #3
Occams_Razor
[ QUOTE ]
tongsli said:
OC,
[ QUOTE ]
[/ QUOTE ]
<font color="red"> The Golf does need the euro bumper and euro rebar to do this. The US bumper is different and the euro rebar doesn't fit behind it from what I have read. </font>
<font color="red"> The advantage of the kit is that it has everything you need in one place with the correct length hose, connectors, pumps, etc. If you want to use the Hella wiring you don't even need Relay 192. </font>
[ QUOTE ]
Just to clarify. To complete the kit for a Jetta you will need in ADDITION TO THE KIT the following parts from Germany, <font color="red">(unless John at IMPEX relents and deceides to bring some in. Last time I asked they said the part numbers was obsolete! ): </font>
[/ QUOTE ]
Any thoughts?
L
[/ QUOTE ]
I will have to play with that. I seemed to notice that it will squirt if you hold the winshield washer up continuously but if you just hit it once you have to do it 4 times before the headlight washers popup.
BTW For all you Golf aficionados I have the nozzles and covers from my kit that I will not be using as well as the Hella wiring harness.
Make an offer! [img]/images/graemlins/grin.gif[/img]
Old October 19th, 2003, 17:04   #4
DC-TDIWagon
Location: DC (really Fairfax county, but it is easier to say DC)
Fuel Economy: ?/38/?
I have a question about the nozzle covers on the bumper. They need to be painted. What's everyone doing to get them painted?
Brian
DC-TDIWagon is offline   Reply With Quote
Old October 19th, 2003, 20:48   #5
Occams_Razor
[ QUOTE ]
Brian
[/ QUOTE ]
Funny you ask. A friend today asked me the same thing...
I took the covers to a place near my apt. called Dealers Choice. Small paint jobs are no problem for them. That is what they specialize in; chip repair and dent removal.
Look in the phonebook or ask around at any auto detailer. They will probably know of similiar outfits that can do the job and not charge you an arm and a leg.
I paid $50.00 for the 2 covers, (painted silver and clear coated), and my grill, (satin black and baked in the oven to cure it.)
Old October 29th, 2003, 20:23   #6
Sawdust
Great post. Question, i have an r32 bumper with euro rebar. now the r32 bumper will not be painted untill spring. my question is do you think the us bumper with euro rebar i can install the headlight washers? i don't care if the caps fit 100% perfect but will the bumper even alow me to do it.
Sawdust is offline   Reply With Quote
Old October 29th, 2003, 21:44   #7
Occams_Razor
[ QUOTE ]
[/ QUOTE ]
Not sure since I don't have a Golf.
You might want to ask on VW Vortex.
Old November 10th, 2003, 17:11   #8
DC-TDIWagon
Does anyone know where to find the wiring diagram if you want to use the Hella wiring?
Brian
Old November 10th, 2003, 17:32   #9
Sawdust
[ QUOTE ]
Brian
[/ QUOTE ]
http://bambergvr6.50megs.com/hella_washer.htm
he explains how to do it here, but they are very very simple.
red to + battery
brown to - battery
purple to green with white stripe from old washer pump.
black to green with brown stripe from old washer pump.
blue and brown with black connector is for the new washer pump.
white with plastic connector is for the power from the headlight.
i think that is it. [img]/images/graemlins/smile.gif[/img]
Old November 10th, 2003, 17:44   #10
DC-TDIWagon
Thanks! It was the white wire that I was clueless about.
Old November 10th, 2003, 21:36   #11
tongsli
Brian,
I managed to paint my own stubby mirror cap silver. You can get the OEM paint in cans, just use your VIN to place the order.
Those caps are pretty small. I bet you could do a great job on them!
Lito
Old November 11th, 2003, 08:31   #12
DC-TDIWagon
Ok, another dumb question. Did you guys not re-attach the center bumper suuport? The euro bumper rebar has only on hole that doesn't line up with the support that comes on the car. Kennedy gave me a part number for a new support, but it is the same as the one I already have with 2 screw holes.
Brian
Old November 12th, 2003, 18:22   #13
DC-TDIWagon
Your instructions helped me considerably when I put my washers in yesterday. I ended up using the Hella wiring. It is set up to only spray when the lights are on. I also had to remove a wire guide that sat under the old tank. I just could not get the wiring harness for the lights, washer fluid level sensor, and side marker to route properly to reach everything with that wire guide there. I also didn't remove the intercooler. I did remove the fuel filter(just out of the bracket), the fuel filter bracket, the headlight, and the intercooler hoses.
I was worried about those fittings that go on the hoses between the new pump and the headlight washers. On my passenger side sprayer body the fitting wouldn't stay tightly "snapped" into position. I was worried it would pop off when I tried to use the washers, but it didn't(yet).
To cut the holes in the bumper I just drilled a bunch of small holes around the outline on my bumper cover. I have a wagon so I had the dimples. Then I just used a razor blade(like the ones you can use to cut drywall) and cut between the holes. It worked surprisingly well. Then I smoothed out the edges with the razor.
The only thing about the install that I don't like is that since I used the Hella wiring I have this relay block near my washer fluid tank and there is not good place to mount it. Oh, I also should mention that in addition to the euro rebar, you need a different lock carrier/support.
Brian
Old November 12th, 2003, 20:13   #14
Occams_Razor
Oops! [img]/images/graemlins/rolleyes.gif[/img]
Forgot to add in my instructions that I removed the wire guide also! Sorry..
I didn't use the center support bracket and have had no problems so that is why I didn't include it in my explanation. (I should put the number of the bracket in there just for completness sake. As soon as I look it up I will.) [img]/images/graemlins/grin.gif[/img]
Correct number has been added.
Old December 6th, 2003, 16:02   #15
DC-TDIWagon
Here is a good side by side of the different bumper rebars. It should be pretty obvious from this picture that ordering the part will be easier than trying to modify your current US one.
Page generated in 0.19708 seconds with 10 queries
[Output: 138.78 Kb. compressed to 118.74 Kb. by saving 20.04 Kb. (14.44%)]
