Old February 18th, 2019, 10:10   #1
JELLOWSUBMARINE
JELLOWSUBMARINE's Avatar
Default DPF newbe questions
I'm not new to diesel engines in general. Having worked on them and have owned a variety of "dirty" diesels. I am however new to the DPF operation as far as actual hands on road time. As a new 2011 JSW TDI owner I have unanswered questions on its operation. T.I.A. to experienced driver input that will help myself and possibly others new to the game.
1) I've gathered the DPF regenerates every 5-600 miles?
2) Is it time/mileage or computer parameter demanded?
3) What are the indicators its happening?
4) I've gathered there are 2 emissions dealt with. Soot and ash. Soot burns off, ash accumulates?
5) Is there an actual numeric value assigned to soot and ash amounts?
6) Does fuel quality effect these levels? If so will filtration help?
7) Can DPF be renewed or is it a throw away once its plugged?
JELLOWSUBMARINE is offline   Reply With Quote
Old February 22nd, 2019, 23:20   #2
jerrymander
jerrymander's Avatar
I know the answers to some of these. I ended up removing the DPF quickly on all of my vehicles, however.
1) Yes, generally, but it is variable.
2) It's a computer parameter. I think it calculates soot buildup somewhere and regenerates when that passes a threshold.
3) Your car feels lethargic and mileage drops. It can be subtle sometimes. Other times it will be quite noticeable (uphill in the wind)
4) More or less, yes
5) Yes, it is stored as a value that can be read by the VCDS (VW-specific OBD2 device: https://www.ross-tech.com/)
6) I am not completely sure, but it most likely does. I am also pretty sure that the oem filtration setup - despite shortcomings - is adequate. I know a lot of people here put aftermarket, additional filters on theirs.
7) Throw away. Service at the dealership is $1400(?) but should be covered under the emissions warranty. Life is about 100,000 miles(?). not sure
Now, having said all that, here is a stellar resource for your new vehicle: https://www.myturbodiesel.com/wiki/d...-pictures-tdi/
jerrymander is offline   Reply With Quote
Old February 23rd, 2019, 12:18   #3
JELLOWSUBMARINE
Great info. thanks
I assume you don't have an annual emissions test?
Old February 24th, 2019, 13:14   #4
Mattyoctavia
I’m currently at 246,000 miles on my original dpf, although I did clean it using a jet washer at 190,000 as my ash load was getting a little high. Never had any trouble with it though. I try to let it complete it’s regenerations as much as I can but otherwise just let it do it thing.
Regular oil changes with good quality low ash oil and good quality fuel is key, along with regular longish trips. My biggest tip is, maintain it well and just enjoy the car ��
Mattyoctavia is offline   Reply With Quote
Dpf questions Bsmsmd VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 2 November 10th, 2015 08:15
DPF questions.. xreyuk TDI 101 26 October 14th, 2014 04:41
Newbe with some questions on TDI sportflyer TDI 101 6 August 25th, 2010 10:56
4 Questions from a Newbe vinpecora TDI 101 12 November 17th, 2009 13:18
Page generated in 0.14555 seconds with 11 queries
[Output: 65.32 Kb. compressed to 58.70 Kb. by saving 6.62 Kb. (10.14%)]
