Old February 15th, 2019, 18:34   #1
Chris Bell
Default Please check your wiring harness for me...
Could someone please check their large wiring harness going into the fuse/relay box and see if it is routed as mine is in this photo? The two arrows show where the kinked harness contacts both the back side of the left headlight and the front corner of the fuse/relay box. This hasn't resulted in any abrasion wear yet, but it doesn't look correctly routed.
Prior to purchase of this stop-sale car, the dealer replaced the wiring harnesses for power steering and oil level sensor (due to rodent damage), both of which are below this area and I'm wondering if during reassembly this section of the main harness was mis-routed.
TIA.
'15 GSW SE 6MT
'01 Golf 5MT
'97 Passat sedan
'96 Passat variant
'99 BMW M3 Cabrio
Chris Bell is offline   Reply With Quote
Old February 15th, 2019, 18:42   #2
Iko
Under the ECU there is cable tray where most of the wiring that comes out of the Fuse boxes is run thru. It's possible that the dealer didnt fit the wires in properly. I dont remember having that much slack coming out of the box last time I was working on the horn alarm.
But then again the ECU it wont be properly seated in the bracket if the cabling is not flattened and run inside the tray.
Sent from my SM-G965U using Tapatalk
Iko is offline   Reply With Quote
Old February 15th, 2019, 19:50   #3
gwc
Fuel Economy: 48-50 mpg
Mine for reference...2015 Golf TDI S model
gwc is online now   Reply With Quote
Old February 16th, 2019, 05:02   #4
Chris Bell
Excellent! Thanks a million, gwc.
'15 GSW SE 6MT
'01 Golf 5MT
'97 Passat sedan
'96 Passat variant
'99 BMW M3 Cabrio
Wiring Harness/Glow Plugs/ Check engine light Strack VW MKIV-A4 TDIs (VE and PD) 33 September 18th, 2017 15:43
05 passat ECU wiring harness check LarryT VW B5 Passat TDIs 31 May 26th, 2017 18:07
How to remove the B4 engine wiring harness connector? Glow plug harness content 914rrr VW MKIII-A3/B4 TDIs 11 March 4th, 2010 14:50
Engine Wiring Harness Question...Swap a Mk3 Harness for a B4? G60ING VW MKIII-A3/B4 TDIs 2 August 10th, 2007 09:18
Wiring Harness swap 99.5 VW Jetta to 04 harness thejestertdi Upgrades (non TDI Engine related) 0 September 19th, 2005 23:40
Page generated in 0.11512 seconds with 11 queries
[Output: 62.33 Kb. compressed to 55.84 Kb. by saving 6.49 Kb. (10.41%)]
