Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Audi SUVs (Q7 & Q5) and other V6 TDIs
Audi SUVs (Q7 & Q5) and other V6 TDIs Discussions area for Audi Q7 and Q5 TDI (2009+ in Canada & the US) as well as others with the V6 TDI such as the A6, A7 and A8 sedans.
Old February 15th, 2019, 05:35   #1
A1sailor
Default 8 Speed ZF transmission -how many litres for a fluid change?
Does anyone know how many litres needed for a fluid change in the 8 Speed ZF transmission?
I read a dry fill was about 9.5 l .
A1sailor is offline   Reply With Quote
Old February 15th, 2019, 07:08   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Alldata shows drain and fill at 3.6 - 4.0 liters. I'd say that is about right.
If you drop the pan and change the filter, it is closer to 5 liters.
We hook the cooler pipes to a machine and flush them, 14 liters, which is far better and less messy.
oilhammer
www.cardocautomotive.com
Old February 16th, 2019, 05:48   #3
A1sailor
Thanks oilhammer, it will be a filter change along with the drain. For the filter, Meyle has a kit available with the gasket and pan bolts at a lower cost vs the OEM. Meyle is an OEM supplier and I have used them for filters in other German cars. Do you think the transmission filter needs to be original VAG or is Meyle ok to use?
Old February 24th, 2019, 09:26   #4
mech644
For a transmission that has a retail price of 6k I’d get the VW filter and pan gasket. About $250 from idparts or fcpeuro.
In my experience Meyle parts have not been OEM quality, maybe the Q7/Touareg parts are better.
2012 Platinum S-line A3 DSG- bought back by VW
2000 Golf 5spd, 301k, the usual mods, sits forlornly in the backyard.
2006 Jetta DSG- gone
2015 GHB SEL 1.8 tsi
2014 Touareg
mech644 is offline   Reply With Quote
Change 6-Speed Manual Transmission Fluid Jeff7 VW MKV-A5 Golf/Jettas 15 August 26th, 2017 01:09
Anyone have experience with this fluid change kit or fluid for transmission? VincenzaV TDI 101 8 July 24th, 2015 10:50
Transmission Fluid Change - Automatic vs Manual Transmission tca32123 TDI 101 11 May 20th, 2014 18:32
5-Speed Manual Transmission Fluid Change Kier Fuels & Lubricants 10 January 19th, 2007 23:14
When do you change the 5 speed Transmission fluid (if ever)? TEXAS_TDI VW MKIV-A4 TDIs (VE and PD) 8 August 1st, 2002 14:57
Page generated in 0.15490 seconds with 11 queries
[Output: 62.63 Kb. compressed to 56.07 Kb. by saving 6.56 Kb. (10.48%)]
