Old February 12th, 2019, 20:58   #1
Hurleyss
Default Timing belt time
Not sure if this us the right spot but...
I am approaching having to change my timing belt in my 2005 VW Passat wagon tdi and I want yo know what else to do/change once its opened up. I believe the 05 pd engine has some flaws that can be fixed around the time the timing belt gets done....?
Hurleyss is offline   Reply With Quote
Old February 12th, 2019, 23:15   #2
peiphil
Get the whole kit with the water pump and tensioner etc.
peiphil is offline   Reply With Quote
Old February 13th, 2019, 03:32   #3
PickleRick
PickleRick's Avatar
I think he's referring to the balance shaft delete.
Kerma tdi on your coast is where I got my timing belt kit and balance shaft delete kit. They sell all oem or oe replacement parts. Prices were fair. I may have saved a few bucks buying each and every item alone from various vendors but i wanted thus knocked out in a weekend so when parts arrived my motor was already on the stand, my coolant, oil, oil filter, permatex gasket maker, drill, tap, locltite and plug was ready to go. I already had vcds on hand. Only specialty tool i used was the crank/cam lock tool cheap from eBay(and vcds for torsion value). I used a grinder with a zip wheel to remove the old crank gear.
I didn't buy a Bentley manual, i paid the 11 bucks or so for the myturbodiesel membership where they have a long how to with pics.
For my 5 speed swap i used Levi Jeffery 5 speed conversion video on youtube.
Nobody exists on purpose. Nobody belongs anywhere. We’re all going to die. Come watch TV.
PickleRick is offline   Reply With Quote
Old February 14th, 2019, 06:32   #4
imo000
imo000's Avatar
Fuel Economy: Good enough
Besides the timing belt kit, to repair the balance shaft and replace the camshaft will cost more than your car is worth. Do you have enough $$$ to fix this?
imo000 is offline   Reply With Quote
Time For a Timing Belt bobo Jetta Ontario 4 February 13th, 2013 21:30
Its timing belt time! fatman VW MKIV-A4 TDIs (VE and PD) 13 August 22nd, 2010 05:29
Timing belt time jetwrench VW MKIV-A4 TDIs (VE and PD) 1 March 1st, 2005 18:43
Its time for a Timing belt !! Need Help please !! Delorean VW MKIV-A4 TDIs (VE and PD) 0 August 9th, 2004 09:39
TIMING BELT TIME STRANGETDI Eastern USA 20 January 29th, 2004 13:10
Page generated in 0.14947 seconds with 11 queries
[Output: 62.58 Kb. compressed to 56.05 Kb. by saving 6.53 Kb. (10.44%)]
