Old February 12th, 2019, 20:23   #1
Nuje
Fuel Economy: 1200km/tank (Mk4); 750km/tank (Mk7)
Default Charging Mk7 Battery
I've had my Mk7 GSW (Highline / SEL with KESSY) parked for about six weeks now - been traveling and having fun in the Mk4 and snow - and when checking a VCDS setting today (didn't start engine), I got a "12V battery is low...turn off accessories" or something like that.
So - figuring that I should top up the battery before I get it on the road again, I'm wondering if any fussing needs to be done with the battery charging, or do I just plug in my old-timey Canadian Tire (20yr. old version of this) and wait for the light to turn green?
Nuje is online now   Reply With Quote
Old February 12th, 2019, 21:21   #2
turbobrick240
turbobrick240's Avatar
That charger will work great. Use the lower 2 amp setting and let it charge overnight preferably.
Old February 13th, 2019, 00:24   #3
neimis
I've been charging my Mk7 battery normally (with a trickle charger), no special treatment, and it's fine.
You do know to keep your Mk7 locked, as the battery drains faster when it is unlocked?
I found that out the hard way...
92 Passat TD
01 Golf GL TDI
15 Golf Trendline TDI
neimis is offline   Reply With Quote
Old February 13th, 2019, 05:13   #4
740GLE
locked or unlocked I think it has more to do with the proximity of the kessy key? keep it 20-40 feet away otherwise the car will be waiting for you to start it or prevent it from "going to sleep". I believe it also helps save the kessy battery life.
Old February 13th, 2019, 07:23   #5
Chris Bell
Could you elaborate on what happened?
'15 GSW SE 6MT
'01 Golf 5MT
'97 Passat sedan
'96 Passat variant
'99 BMW M3 Cabrio
Chris Bell is offline   Reply With Quote
Old February 13th, 2019, 08:51   #6
neimis
My battery drained fairly quickly. The car was sitting and not being driven, though.
92 Passat TD
01 Golf GL TDI
Old February 13th, 2019, 10:22   #7
bizzle
bizzle's Avatar
Like 740GLE mentioned, that could have been due to the key being in range. Was the key hanging/stored close enough to keep communicating with the car while it was sitting?
bizzle is offline   Reply With Quote
Old February 13th, 2019, 23:45   #8
neimis
The key was probably 50 or 60 feet away, but that is probably a moot point as I don't have Keyless Entry.
From page 313 in my owner's manual:
"What drains the vehicle battery?...
Leaving the vehicle unlocked for several days when not in use..."
92 Passat TD
01 Golf GL TDI
Old February 13th, 2019, 23:52   #9
bizzle
bizzle's Avatar
I wonder if that applies to your model. The control system is probably left listening for a lock signal on a keyless entry system, but I don't know why that would affect you if you don't have keyless entry.
But are you talking about keyless entry or KESSY? Even my '98 has keyless entry.
Old February 14th, 2019, 18:04   #10
volmaniac
volmaniac's Avatar
TDI(s): 02 Golf GLS
Fuel Economy: around 50 mpg
Car: Whatcha doing over there baby
Key: Just hanging out, maybe waiting for somebody to pick me up
Car: mmmm wish they would pick you up and bring you over to me
Key: Do I turn you on?
Car: Yeah baby you do
Key: Well maybe I will slide right in then
Car: Oh yeah get me started baby
Key: You getting hot?
Car: Don't be ridiculous, I'm a diesel and it takes forever to get me hot.
2002 gls golf
Originally Posted by foxracer1 View Post
Wars are fought over religion, money, land, and brand of injectors for a TDI
volmaniac is offline   Reply With Quote
Old February 14th, 2019, 22:57   #11
neimis
Oops, that was dumb of me, of course I have keyless entry.
I should have said "I don't have KESSY".
92 Passat TD
01 Golf GL TDI
Battery not charging! tdileon VW MKIV-A4 TDIs (VE and PD) 3 November 22nd, 2016 18:45
Battery / generator light on, alternator not charging, battery holds charge Keven VW MKIV-A4 TDIs (VE and PD) 16 December 12th, 2013 13:22
Battery Light Blinking Battery Not Charging, Hard To Start hardmeat VW MKIV-A4 TDIs (VE and PD) 3 November 2nd, 2009 15:56
Charging battery bottlediger TDI 101 7 December 9th, 2008 09:16
Charging battery 3800rpmDiesel TDI 101 4 December 5th, 2008 11:24
Page generated in 0.14609 seconds with 11 queries
[Output: 104.48 Kb. compressed to 88.33 Kb. by saving 16.14 Kb. (15.45%)]
