Hello,
Did you find the cause? I have a vehicle doing the same except it won't clear upon restart unless I do it via scanner. I've added the faults below
Sunday,30,January,2022,07:20:52:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WVWZZZ6RZBU082680 License Plate: VWPOLO
Address 01: Engine Labels: 03L-906-023-CAY.clb
Control Module Part Number: 03L 906 023 MH HW: 03L 907 425 B
Component and/or Version: R4 1.6l TDI H33 9980
Software Coding: 00254016002500080000
Work Shop Code: WSC 31414 790 50316
ASAM Dataset: EV_ECM16TDI02103L906023MH 003013 (VW25)
ROD: EV_ECM16TDI02103L906023LK_SK25.rod
VCID: 78FF5DE7C3D3424BFB-802C
1 Fault Found:
7384 - Boost Pressure Regulation
P0299 00 [167] - Control Range Not Reached
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 231909 km
Date: 2022.01.30
Time: 19:16:47
Engine RPM: 2766.75 /min
Normed load value: 52.9 %
Vehicle speed: 51 km/h
Coolant temperature: 48 ∞C
Intake air temperature: 29 ∞C
Ambient air pressure: 940 mbar
Voltage terminal 30: 13.779 V
Unlearning counter according OBD: 40
Charge air pressure: specified value-MAP_SP_MMV: 1985.63 hPa
Charge air pressure: actual value-MAP_MMV: 1419.38 hPa
Air mass: actual value (mg/stroke)-MAF_MES: 559.521 mg/stroke
EGR Solen.val.: actual value-ANG_EGRV[0]: 0.378 %
Throttle valve adapter: actual value-ANG_THR[0]: 95.996 %
Charge air pressure actuator: acknowledgment-ANG_BPA[0]: 74.200 %
Engine torque-TQI_SP: 125.06 Nm
Readiness: 0 0 0 0 0
*********************** LOG 2 AFTER CLEARING CODE FOR 7384 - Boost Pressure Regulation and test drive again ***************
Sunday,30,January,2022,07:26:42:00009
www.Ross-Tech.com
VIN: License Plate: VWPOLO
1 Fault Found:
10116 - Fuel Rail/System Pressure
P0087 00 [167] - Too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 231909 km
Date: 2022.01.30
Time: 19:25:15
Engine RPM: 3427.50 /min
Normed load value: 78.8 %
Vehicle speed: 41 km/h
Coolant temperature: 67 ∞C
Intake air temperature: 35 ∞C
Voltage terminal 30: 13.666 V
Fuel high-pressure: actual value-FUP_FIL: 118.335 MPa
Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000000
Fuel level-FTL_CAN: 15 l
Fuel temperature-TFU: 40 ∞C
Fuel Metering Valve-VCV: 34.996 %
Fuel Pressure Regulator Valve-PCV: 40.775 %
Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 136273.193 kPa
Readiness: 0 0 0 0 1
Sunday | 30 | January | 2022 | 07:15:39:00009-VCID:78FF5DE7C3D3424BFB-802C | VCDS Version: Release 21.3.0 | Data version: 20210226 DS325.0 | | | | | | | | | | | |
03L 906 023 MH | ADVMB | R4 1.6l TDI H33 9980 | | | | | | | | | | | | | | | |
| | G022 | F0 | G028 | F0 | G029 | F0 | G041 | F0 | G052 | F0 | G100 | F0 | G101 | F0 | G116 | F0 |
Marker | TIME | Loc. IDE00188-ENG102817 | TIME | Loc. IDE00201-ENG102664 | TIME | Loc. IDE00304-ENG101210 | TIME | Loc. IDE00357-ENG99842 | TIME | Loc. IDE00371-ENG100275 | TIME | Loc. IDE00475-ENG99518 | TIME | Loc. IDE00476-ENG104101 | TIME | Loc. IDE00589 | |
| STAMP | Fuel high-pressure: actual value-FUP_FIL | STAMP | High fuel pressure: specified value-FUP_SP_KPA | STAMP | Fuel level-FTL_CAN | STAMP | Fuel temperature-TFU | STAMP | Fuel consumption-FCO_T | STAMP | Fuel Pressure Regulator Valve-PCV | STAMP | Fuel Metering Valve-VCV | STAMP | Fuel pressure | |
| | MPa | | kPa | | l | | °C | | ml/s | | % | | % | | kPa rel | |
| 0.82 | 29.626 | 1.04 | 29095.459 | 1.26 | 15 | 1.48 | 29 | 0.01 | 0.1310 | 0.21 | 15.715 | 0.41 | 21.886 | 0.62 | 26660 | |
| 2.54 | 28.619 | 2.75 | 28601.074 | 2.96 | 15 | 3.17 | 29 | 1.69 | 0.1318 | 1.89 | 15.456 | 2.10 | 21.941 | 2.31 | 29270 | |
| 4.22 | 29.089 | 4.42 | 29406.738 | 4.63 | 15 | 4.84 | 29 | 3.37 | 0.1333 | 3.58 | 15.407 | 3.79 | 21.950 | 4.01 | 30570 | |
| 5.86 | 30.859 | 6.06 | 30810.547 | 6.29 | 15 | 6.51 | 29 | 5.05 | 0.1348 | 5.26 | 15.860 | 5.46 | 23.843 | 5.66 | 30790 | |
| 7.56 | 29.547 | 7.78 | 29089.355 | 7.98 | 15 | 8.19 | 29 | 6.73 | 0.1355 | 6.94 | 15.982 | 7.14 | 22.598 | 7.35 | 27900 | |
| 9.26 | 28.992 | 9.48 | 29028.320 | 9.69 | 15 | 9.90 | 29 | 8.40 | 0.1375 | 8.62 | 15.588 | 8.83 | 22.533 | 9.04 | 31440 | |
| 10.98 | 29.419 | 11.18 | 29693.604 | 11.39 | 15 | 11.60 | 29 | 10.12 | 0.1390 | 10.32 | 15.692 | 10.54 | 22.513 | 10.76 | 29350 | |
| 12.61 | 29.144 | 12.82 | 29144.287 | 13.04 | 15 | 13.25 | 29 | 11.80 | 0.1398 | 12.01 | 15.511 | 12.20 | 22.279 | 12.41 | 27560 | |
| 14.29 | 29.022 | 14.51 | 29205.322 | 14.72 | 15 | 14.92 | 29 | 13.46 | 0.1413 | 13.67 | 15.750 | 13.88 | 22.046 | 14.08 | 31300 | |
| 15.96 | 28.998 | 16.17 | 28930.664 | 16.37 | 15 | 16.58 | 29 | 15.13 | 0.1428 | 15.34 | 15.475 | 15.55 | 22.095 | 15.75 | 29690 | |
| 17.63 | 40.076 | 17.84 | 38165.283 | 18.05 | 15 | 18.25 | 29 | 16.80 | 0.1435 | 17.01 | 16.083 | 17.22 | 22.716 | 17.42 | 39090 | |
| 19.30 | 36.560 | 19.51 | 36444.092 | 19.72 | 15 | 19.92 | 29 | 18.46 | 0.1458 | 18.67 | 16.206 | 18.88 | 23.212 | 19.08 | 34810 | |
| 20.96 | 31.091 | 21.16 | 30413.818 | 21.37 | 15 | 21.58 | 29 | 20.13 | 0.1480 | 20.34 | 15.891 | 20.54 | 22.060 | 20.76 | 33200 | |
| 22.64 | 33.868 | 22.85 | 33642.578 | 23.06 | 15 | 23.26 | 29 | 21.80 | 0.1490 | 22.01 | 16.885 | 22.23 | 22.835 | 22.43 | 34050 | |
| 24.32 | 32.776 | 24.52 | 32116.699 | 24.73 | 15 | 24.95 | 29 | 23.47 | 0.1518 | 23.68 | 16.248 | 23.90 | 22.879 | 24.11 | 31850 | |
| 25.98 | 33.228 | 26.19 | 33123.779 | 26.40 | 15 | 26.62 | 29 | 25.16 | 0.1543 | 25.36 | 16.048 | 25.57 | 23.354 | 25.78 | 33880 | |
| 27.66 | 32.935 | 27.86 | 32708.740 | 28.08 | 15 | 28.29 | 30 | 26.83 | 0.1555 | 27.03 | 16.595 | 27.24 | 23.582 | 27.45 | 32740 | |
| 29.34 | 31.958 | 29.54 | 31665.039 | 29.75 | 15 | 29.96 | 30 | 28.51 | 0.1578 | 28.72 | 15.768 | 28.92 | 22.795 | 29.13 | 29500 | |
| 30.99 | 29.724 | 31.19 | 29779.053 | 31.40 | 15 | 31.61 | 30 | 30.16 | 0.1600 | 30.36 | 15.489 | 30.58 | 22.273 | 30.78 | 27680 | |
| 32.67 | 31.342 | 32.88 | 31829.834 | 33.09 | 15 | 33.31 | 30 | 31.84 | 0.1613 | 32.06 | 16.286 | 32.26 | 23.523 | 32.47 | 33720 | |
| 34.34 | 78.302 | 34.55 | 56604.004 | 34.76 | 16 | 34.97 | 30 | 33.50 | 0.1635 | 33.71 | 18.704 | 33.93 | 19.337 | 34.14 | 78890 | |
| 36.00 | 68.353 | 36.21 | 65270.996 | 36.43 | 16 | 36.64 | 30 | 35.17 | 0.1683 | 35.38 | 28.239 | 35.59 | 18.774 | 35.79 | 62430 | |
| 37.69 | 96.643 | 37.89 | 93914.795 | 38.10 | 16 | 38.30 | 30 | 36.85 | 0.1715 | 37.07 | 31.831 | 37.26 | 20.407 | 37.48 | 97380 | |
| 39.36 | 31.122 | 39.57 | 27038.574 | 39.77 | 16 | 39.98 | 30 | 38.51 | 0.1813 | 38.72 | 17.166 | 38.93 | 18.283 | 39.15 | 35000 | |
| 41.04 | 27.759 | 41.25 | 31402.588 | 41.46 | 16 | 41.68 | 30 | 40.18 | 0.1798 | 40.39 | 14.839 | 40.62 | 21.565 | 40.84 | 24950 | |
| 42.76 | 30.157 | 42.97 | 29907.227 | 43.17 | 16 | 43.38 | 30 | 41.89 | 0.1810 | 42.12 | 15.462 | 42.35 | 22.607 | 42.54 | 29860 | |
| 44.42 | 32.080 | 44.63 | 32360.840 | 44.85 | 16 | 45.07 | 30 | 43.60 | 0.1818 | 43.81 | 15.785 | 44.01 | 23.413 | 44.22 | 29970 | |
| 46.11 | 30.823 | 46.32 | 31451.416 | 46.52 | 16 | 46.73 | 30 | 45.26 | 0.1835 | 45.47 | 15.744 | 45.68 | 22.481 | 45.89 | 29140 | |
| 47.80 | 31.244 | 48.00 | 31427.002 | 48.21 | 16 | 48.43 | 30 | 46.94 | 0.1855 | 47.14 | 15.819 | 47.37 | 22.803 | 47.59 | 30110 | |
| 49.50 | 62.488 | 49.70 | 51062.012 | 49.91 | 16 | 50.14 | 30 | 48.64 | 0.1863 | 48.87 | 23.610 | 49.08 | 18.025 | 49.29 | 68800 | |
| 51.18 | 77.661 | 51.39 | 74084.473 | 51.59 | 16 | 51.80 | 30 | 50.36 | 0.1903 | 50.56 | 28.786 | 50.77 | 20.015 | 50.97 | 72920 | |
| 52.87 | 79.944 | 53.09 | 82464.600 | 53.30 | 16 | 53.50 | 30 | 52.01 | 0.1978 | 52.23 | 31.114 | 52.44 | 19.655 | 52.65 | 81390 | |
| 54.57 | 87.408 | 54.77 | 89233.398 | 54.96 | 16 | 55.16 | 30 | 53.71 | 0.2023 | 53.93 | 31.955 | 54.16 | 20.694 | 54.36 | 88590 | |
| 56.21 | 108.508 | 56.43 | 106072.998 | 56.68 | 16 | 56.89 | 30 | 55.36 | 0.2123 | 55.57 | 34.773 | 55.79 | 22.276 | 56.00 | 107100 | |
| 57.94 | 79.095 | 58.16 | 79522.705 | 58.37 | 16 | 58.59 | 30 | 57.08 | 0.2268 | 57.29 | 31.522 | 57.51 | 19.223 | 57.73 | 80630 | |
| 59.63 | 93.726 | 59.83 | 93054.199 | 60.04 | 16 | 60.26 | 30 | 58.80 | 0.2303 | 59.00 | 32.445 | 59.21 | 21.613 | 59.42 | 92160 | |
| 61.34 | 94.031 | 61.54 | 95806.885 | 61.75 | 16 | 61.96 | 30 | 60.47 | 0.2395 | 60.68 | 33.255 | 60.90 | 21.495 | 61.12 | 91550 | |
| 63.01 | 108.179 | 63.23 | 103375.244 | 63.44 | 16 | 63.65 | 30 | 62.19 | 0.2513 | 62.39 | 35.330 | 62.59 | 23.311 | 62.80 | 108470 | |
| 64.70 | 34.241 | 64.92 | 28350.830 | 65.12 | 16 | 65.33 | 30 | 63.85 | 0.2588 | 64.06 | 19.702 | 64.28 | 18.231 | 64.48 | 37900 | |
| 66.40 | 25.580 | 66.60 | 25091.553 | 66.80 | 16 | 67.01 | 30 | 65.54 | 0.2580 | 65.76 | 15.097 | 65.98 | 18.553 | 66.19 | 26540 | |
| 68.08 | 30.725 | 68.28 | 30456.543 | 68.49 | 16 | 68.70 | 30 | 67.22 | 0.2573 | 67.45 | 16.347 | 67.67 | 23.074 | 67.87 | 30000 | |
| 69.75 | 88.525 | 69.96 | 71234.131 | 70.20 | 16 | 70.44 | 30 | 68.90 | 0.2595 | 69.11 | 24.879 | 69.32 | 20.146 | 69.54 | 88230 | |
| 71.47 | 83.130 | 71.70 | 84680.176 | 71.92 | 15 | 72.12 | 31 | 70.64 | 0.2628 | 70.85 | 30.600 | 71.05 | 23.120 | 71.26 | 81050 | |
| 73.19 | 107.068 | 73.41 | 110626.221 | 73.60 | 15 | 73.82 | 31 | 72.32 | 0.2703 | 72.53 | 33.434 | 72.74 | 22.931 | 72.95 | 104580 | |
| 74.87 | 114.789 | 75.08 | 118304.443 | 75.28 | 15 | 75.49 | 30 | 74.03 | 0.2843 | 74.23 | 35.638 | 74.44 | 23.363 | 74.65 | 113980 | |
| 76.54 | 77.917 | 76.76 | 62072.754 | 76.96 | 15 | 77.20 | 31 | 75.70 | 0.2930 | 75.91 | 32.463 | 76.11 | 23.839 | 76.32 | 75370 | |
| 78.22 | 31.177 | 78.45 | 28576.660 | 78.67 | 15 | 78.86 | 31 | 77.42 | 0.2935 | 77.62 | 17.093 | 77.82 | 18.324 | 78.02 | 33720 | |
| 79.92 | 44.830 | 80.12 | 51074.219 | 80.32 | 15 | 80.52 | 31 | 79.07 | 0.2915 | 79.29 | 18.314 | 79.50 | 23.701 | 79.70 | 44010 | |
| 81.56 | 84.528 | 81.77 | 78460.693 | 81.98 | 15 | 82.20 | 31 | 80.72 | 0.2920 | 80.95 | 29.813 | 81.17 | 20.848 | 81.36 | 84990 | |
| 83.22 | 102.539 | 83.42 | 102624.512 | 83.63 | 15 | 83.84 | 31 | 82.41 | 0.2983 | 82.61 | 33.545 | 82.82 | 22.754 | 83.02 | 101100 | |
| 84.88 | 109.296 | 85.08 | 111370.850 | 85.28 | 15 | 85.49 | 31 | 84.04 | 0.3103 | 84.25 | 34.962 | 84.46 | 23.567 | 84.69 | 108060 | |
| 86.54 | 114.160 | 86.75 | 115081.787 | 86.96 | 15 | 87.16 | 32 | 85.70 | 0.3173 | 85.90 | 36.102 | 86.12 | 24.390 | 86.34 | 112670 | |
| 88.18 | 115.717 | 88.40 | 118072.510 | 88.61 | 15 | 88.82 | 32 | 87.36 | 0.3330 | 87.56 | 35.902 | 87.77 | 24.530 | 87.97 | 114840 | |
| 89.88 | 118.817 | 90.09 | 120385.742 | 90.30 | 15 | 90.50 | 32 | 89.04 | 0.3500 | 89.26 | 36.543 | 89.47 | 24.915 | 89.67 | 118330 | |
| 91.57 | 118.439 | 91.79 | 117590.332 | 92.00 | 15 | 92.21 | 32 | 90.71 | 0.3590 | 90.93 | 36.615 | 91.14 | 24.997 | 91.35 | 118250 | |
| 93.27 | 98.395 | 93.48 | 91821.289 | 93.69 | 15 | 93.89 | 33 | 92.44 | 0.3755 | 92.65 | 30.690 | 92.86 | 22.517 | 93.06 | 97800 | |
| 94.93 | 38.611 | 95.13 | 30981.445 | 95.32 | 15 | 95.52 | 33 | 94.10 | 0.3833 | 94.30 | 28.697 | 94.50 | 20.663 | 94.72 | 41310 | |
| 96.56 | 28.772 | 96.77 | 28302.002 | 96.98 | 15 | 97.19 | 33 | 95.72 | 0.3818 | 95.96 | 16.080 | 96.15 | 18.643 | 96.36 | 29290 | |
| 98.23 | 26.947 | 98.44 | 27124.023 | 98.64 | 15 | 98.85 | 34 | 97.39 | 0.3788 | 97.59 | 15.355 | 97.80 | 18.916 | 98.01 | 27620 | |
| 99.90 | 26.910 | 100.11 | 33575.439 | 100.31 | 15 | 100.52 | 34 | 99.06 | 0.3758 | 99.26 | 15.457 | 99.48 | 18.909 | 99.69 | 27980 | |
| 101.58 | 26.727 | 101.79 | 36010.742 | 102.00 | 15 | 102.22 | 34 | 100.73 | 0.3743 | 100.96 | 15.848 | 101.17 | 21.155 | 101.38 | 27490 | |
| 103.24 | 31.561 | 103.44 | 32025.146 | 103.65 | 15 | 103.86 | 34 | 102.42 | 0.3740 | 102.63 | 16.051 | 102.82 | 24.831 | 103.03 | 31340 | |
| 104.90 | 33.868 | 105.11 | 37237.549 | 105.32 | 15 | 105.53 | 34 | 104.06 | 0.3745 | 104.27 | 16.429 | 104.50 | 22.896 | 104.70 | 28270 | |
| 106.58 | 61.584 | 106.78 | 55743.408 | 107.00 | 15 | 107.22 | 34 | 105.74 | 0.3748 | 105.94 | 18.935 | 106.15 | 20.872 | 106.37 | 57060 | |
| 108.27 | 61.151 | 108.50 | 59558.105 | 108.73 | 15 | 108.92 | 34 | 107.42 | 0.3775 | 107.63 | 28.880 | 107.84 | 20.401 | 108.06 | 58780 | |
| 109.96 | 90.356 | 110.16 | 90179.443 | 110.37 | 15 | 110.58 | 34 | 109.13 | 0.3805 | 109.33 | 31.853 | 109.54 | 22.224 | 109.75 | 82860 | |
| 111.61 | 100.122 | 111.82 | 100018.311 | 112.03 | 15 | 112.24 | 34 | 110.78 | 0.3843 | 111.00 | 33.948 | 111.20 | 23.026 | 111.40 | 100760 | |
| 113.27 | 100.385 | 113.50 | 99713.135 | 113.71 | 15 | 113.91 | 34 | 112.44 | 0.3940 | 112.65 | 34.268 | 112.86 | 22.881 | 113.06 | 100490 | |
| 114.97 | 90.210 | 115.18 | 66552.734 | 115.39 | 15 | 115.59 | 34 | 114.13 | 0.4035 | 114.34 | 33.804 | 114.54 | 22.623 | 114.75 | 97380 | |
| 116.64 | 50.494 | 116.85 | 60546.875 | 117.07 | 15 | 117.28 | 35 | 115.80 | 0.4073 | 116.01 | 16.765 | 116.24 | 24.197 | 116.44 | 41160 | |
| 118.35 | 77.997 | 118.57 | 76556.396 | 118.79 | 15 | 119.00 | 35 | 117.49 | 0.4073 | 117.72 | 29.735 | 117.94 | 22.589 | 118.14 | 74900 | |
| 120.07 | 87.512 | 120.29 | 87457.275 | 120.50 | 15 | 120.72 | 35 | 119.22 | 0.4125 | 119.43 | 32.079 | 119.64 | 22.832 | 119.85 | 85130 | |
| 121.76 | 90.601 | 121.99 | 90136.719 | 122.21 | 15 | 122.41 | 35 | 120.93 | 0.4193 | 121.14 | 32.762 | 121.34 | 23.515 | 121.55 | 90150 | |
| 123.47 | 93.652 | 123.68 | 92590.332 | 123.89 | 15 | 124.10 | 35 | 122.63 | 0.4230 | 122.84 | 32.983 | 123.04 | 23.270 | 123.25 | 93340 | |
| 125.18 | 95.789 | 125.38 | 94891.357 | 125.59 | 15 | 125.80 | 35 | 124.32 | 0.4308 | 124.53 | 33.278 | 124.76 | 23.267 | 124.98 | 95920 | |
| 126.85 | 53.015 | 127.06 | 29968.262 | 127.26 | 15 | 127.48 | 35 | 126.01 | 0.4390 | 126.24 | 33.818 | 126.44 | 19.472 | 126.64 | 47530 | |
| 128.52 | 27.130 | 128.75 | 26025.391 | 128.97 | 15 | 129.16 | 35 | 127.68 | 0.4375 | 127.89 | 15.634 | 128.09 | 19.290 | 128.30 | 26570 | |
| 130.24 | 29.639 | 130.44 | 29754.639 | 130.64 | 15 | 130.85 | 35 | 129.37 | 0.4340 | 129.57 | 16.481 | 129.78 | 23.050 | 130.01 | 28470 | |
| 131.88 | 83.893 | 132.08 | 76684.570 | 132.28 | 15 | 132.51 | 36 | 131.06 | 0.4330 | 131.27 | 17.270 | 131.48 | 27.483 | 131.68 | 50040 | |
| 133.54 | 105.103 | 133.76 | 101159.668 | 133.99 | 15 | 134.18 | 36 | 132.73 | 0.4353 | 132.92 | 33.984 | 133.13 | 23.544 | 133.34 | 106130 | |
| 135.24 | 85.089 | 135.44 | 89727.783 | 135.64 | 15 | 135.85 | 35 | 134.39 | 0.4448 | 134.59 | 32.146 | 134.80 | 21.709 | 135.01 | 85900 | |
| 136.93 | 96.826 | 137.14 | 97100.830 | 137.35 | 15 | 137.57 | 36 | 136.07 | 0.4518 | 136.28 | 33.577 | 136.51 | 23.460 | 136.74 | 96800 | |
| 138.65 | 44.519 | 138.86 | 29608.154 | 139.06 | 15 | 139.27 | 36 | 137.79 | 0.4560 | 138.00 | 33.517 | 138.22 | 8.565 | 138.43 | 32930 | |
| 140.32 | 28.009 | 140.53 | 27581.787 | 140.76 | 15 | 140.99 | 36 | 139.48 | 0.4588 | 139.69 | 15.790 | 139.92 | 19.104 | 140.13 | 27510 | |
| 142.03 | 50.067 | 142.25 | 51013.184 | 142.46 | 15 | 142.68 | 36 | 141.20 | 0.4553 | 141.40 | 15.399 | 141.61 | 24.783 | 141.82 | 41720 | |
| 143.74 | 78.070 | 143.94 | 74603.271 | 144.14 | 15 | 144.35 | 36 | 142.89 | 0.4568 | 143.09 | 30.988 | 143.30 | 21.701 | 143.51 | 80440 | |
| 145.46 | 60.394 | 145.66 | 60058.594 | 145.86 | 15 | 146.07 | 36 | 144.57 | 0.4585 | 144.78 | 28.818 | 145.01 | 20.282 | 145.24 | 54190 | |
| 147.15 | 31.305 | 147.37 | 27624.512 | 147.58 | 15 | 147.78 | 36 | 146.29 | 0.4595 | 146.52 | 17.664 | 146.72 | 18.864 | 146.93 | 34610 | |
| 148.84 | 27.075 | 149.04 | 26867.676 | 149.27 | 15 | 149.48 | 36 | 148.00 | 0.4560 | 148.20 | 15.730 | 148.41 | 18.973 | 148.63 | 26680 | |
| 150.53 | 27.789 | 150.75 | 29132.080 | 150.94 | 15 | 151.15 | 36 | 149.70 | 0.4543 | 149.90 | 15.120 | 150.11 | 21.519 | 150.32 | 23470 | |
| 152.20 | 29.944 | 152.41 | 30426.025 | 152.62 | 15 | 152.84 | 37 | 151.36 | 0.4523 | 151.56 | 16.194 | 151.78 | 23.064 | 152.00 | 31980 | |
| 153.91 | 33.923 | 154.13 | 31463.623 | 154.35 | 15 | 154.56 | 37 | 153.05 | 0.4518 | 153.28 | 17.569 | 153.50 | 23.196 | 153.70 | 31760 | |
| 155.60 | 32.813 | 155.82 | 34106.445 | 156.04 | 15 | 156.27 | 37 | 154.77 | 0.4515 | 154.97 | 17.349 | 155.18 | 24.568 | 155.39 | 33740 | |
| 157.37 | 30.206 | 157.58 | 29956.055 | 157.79 | 15 | 158.00 | 37 | 156.45 | 0.4510 | 156.81 | 16.837 | 156.94 | 23.785 | 157.15 | 30390 | |
| 159.04 | 30.176 | 159.26 | 30084.229 | 159.45 | 15 | 159.66 | 36 | 158.21 | 0.4505 | 158.42 | 17.578 | 158.62 | 24.828 | 158.83 | 28340 | |
| 160.71 | 59.192 | 160.93 | 52575.684 | 161.13 | 15 | 161.34 | 36 | 159.87 | 0.4503 | 160.09 | 18.658 | 160.30 | 25.964 | 160.51 | 51520 | |
| 162.37 | 49.170 | 162.58 | 47863.770 | 162.81 | 15 | 163.04 | 36 | 161.56 | 0.4513 | 161.78 | 28.323 | 161.97 | 21.603 | 162.17 | 48580 | |
| 164.07 | 42.303 | 164.30 | 36724.854 | 164.50 | 15 | 164.71 | 36 | 163.22 | 0.4518 | 163.42 | 19.501 | 163.63 | 23.682 | 163.85 | 43880 | |
| 165.78 | 32.172 | 165.98 | 34265.137 | 166.18 | 15 | 166.39 | 36 | 164.93 | 0.4525 | 165.15 | 16.765 | 165.36 | 24.046 | 165.56 | 35330 | |
| 167.42 | 35.010 | 167.63 | 34118.652 | 167.82 | 15 | 168.05 | 36 | 166.60 | 0.4528 | 166.81 | 18.289 | 167.02 | 24.136 | 167.22 | 32560 | |
| 169.08 | 34.332 | 169.31 | 34301.758 | 169.52 | 15 | 169.72 | 36 | 168.25 | 0.4533 | 168.46 | 16.862 | 168.67 | 23.874 | 168.88 | 33330 | |
| 170.77 | 34.021 | 170.97 | 33935.547 | 171.18 | 15 | 171.40 | 36 | 169.92 | 0.4533 | 170.13 | 16.833 | 170.35 | 23.933 | 170.56 | 34940 | |
| 172.44 | 33.923 | 172.64 | 34020.996 | 172.85 | 15 | 173.06 | 36 | 171.61 | 0.4535 | 171.82 | 17.038 | 172.04 | 23.795 | 172.24 | 35860 | |
| 174.10 | 31.152 | 174.32 | 30364.990 | 174.54 | 15 | 174.75 | 36 | 173.28 | 0.4535 | 173.47 | 16.580 | 173.68 | 22.736 | 173.89 | 30510 | |
| 175.79 | 27.765 | 175.99 | 27850.342 | 176.22 | 15 | 176.42 | 36 | 174.95 | 0.4523 | 175.16 | 15.897 | 175.37 | 22.621 | 175.58 | 28290 | |
