Old January 26th, 2019, 14:20   #1
keith102
Fuel Economy: .
Default LED reverse light error
I installed a set of Philips LED reverse lights and now I'm getting error light. I thought I read someone post the coding to fix this but can't find it. Anyone resolve this issue and care to share?
keith102 is offline   Reply With Quote
Old January 26th, 2019, 21:27   #2
neimis
Try this:
To recode reverse lights (both left and right sides) to LEDs:
Open VCDS / Select / 09-Cent. Elect. / Security Access - 16 / enter 31347 / Do It / OK / Adaptation - 10 / Channel (drop down menu) / Leuchte28RFL Lasttyp28 / New value (drop down menu) / 43 - allgemeine LED / Do It! / Yes / OK etc.
Repeat for other side:
go back to Channel (drop down menu) / Leuchte29RFL Lasttyp29 / New value (drop down menu) / 43 - allgemeine LED / Do It! / Yes / OK etc.
To increase brightness:
Open VCDS / Select / 09-Cent. Elect. / Security Access - 16 / enter 31347 / Do It / OK / Adaptation - 10 / Channel (drop down menu) / Leuchte28RFL Dimmwert AB 28 / enter new value / 127 (original was 100) / Do It! / Yes / OK etc.
go back to Channel (drop down menu) / Leuchte29RFL – Dimmwert AB 29 / enter new value / 127 (original was 100) / Do It / Yes / OK etc.
I used Phillips LEDs, didn't have a dash light but did have fault codes. Just recoded today, and so far so good. Changes may take 30 minutes or so to take effect.
92 Passat TD
01 Golf GL TDI
15 Golf Trendline TDI
neimis is offline   Reply With Quote
Old January 30th, 2019, 17:28   #3
keith102
Fuel Economy: .
thanks for the help. It worked perfect once I got the bulbs rotated.
any tips for the LED license plate bulbs? They work great, just get the error message. Maybe point me to the cheat list for these so I don't ask dumb questions.
Old January 30th, 2019, 23:19   #4
neimis
Same idea, just use
Leuchte25KZL HA59-Lasttyp 25 /
43 - allgemeine LED (to recode to LED bulbs)
and Leuchte25KZL HA59 – Dimmwert AB 25 / enter new value / 127 (original was 100) (to increase brightness)
92 Passat TD
01 Golf GL TDI
Old January 31st, 2019, 05:12   #5
740GLE
I picked up some bulbs on amazon that were canbus error free, they light up great, no error codes, but the SMD socket design of them caused them to pop out of the housing after a little bit of rough driving.
Good thing they had a whole in the center of the SMD wafer, I just zip tied them into the socket and haven't had an issue since. I'm guessing the hours on them are under 2 total, but darn they light up crazy bright now.
Easy thing to double check.
Old February 8th, 2019, 02:50   #6
keith102
Fuel Economy: .
Originally Posted by neimis View Post
Same idea, just use
and Leuchte25KZL HA59 Dimmwert AB 25 / enter new value / 127 (original was 100) (to increase brightness)
Thanks again for the help. This worked great
Fs: Euro taillights reverse cree led kit - error free and bright fits: Mk6 gti golf Nash_TDI Private TDI Items for Sale/Wanted 0 December 21st, 2016 11:43
Super Easy Reverse Light Upgrade to LED. UzoUba Upgrades (non TDI Engine related) 1 September 25th, 2014 18:07
LED parking light install and error... akrievins VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 10 July 11th, 2014 09:55
LED plate/reverse light resistor toy hauler Audi A3 1 February 17th, 2012 09:40
anyone used these LED reverse light? (for a brighter light) mattds VW MKV-A5 Golf/Jettas 8 October 31st, 2010 19:04
Page generated in 0.11674 seconds with 11 queries
[Output: 74.08 Kb. compressed to 65.00 Kb. by saving 9.08 Kb. (12.26%)]
