Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Eastern USA
Eastern USA Local discussions for those in the Eastern USA. (Vermont, New Hampshire, Massachusetts, Maine, Washington, DC. New York, New Jersey, Connecticut, Rhode Island, Delaware, Maryland, Pennsylvania, Virginia, West Virginia)
Old January 15th, 2019, 06:48   #1
ttcheung
Fuel Economy: 40mpg
Default In NE, do you block your grille during winter?
Anybody in the Massachusetts area block their grilles during the winter? If so, are the benefits noticeable? I commute about 60 miles daily and go up and down 495; my water never seems to reach the midpoint, even when going ~80mph.
If you block your grilles, what foam diameters have you been using? Thank you.
2011 Toffee Brown JSW: 6MT, pano roof, Kerma, Neuspeed/Koni Yellow, ADVAN RS, Diesel Geek SSK
1995 300ZX 2+0
, 1997 Miata, 1998 M3/4/5
ttcheung is offline   Reply With Quote
Old January 15th, 2019, 07:16   #2
KITEWAGON
KITEWAGON's Avatar
Yes I do. I don't know if its noticeable because I put it on before it was very cold out. I didn't do a scientific test. I use the IDparts winter cover. Fits nice. Looks good. My car gets to full temperature (actual 190-200 F using my P3 gauge, not going by built in dial) within about 7-8 miles or so.
If your car is never hitting temp you may have something else going on.
2014 Touareg TDI Executive, Canyon Grey, 130k
2014 JSW TDI, Platinum Grey, 43k
2005 Toyota Tundra Double Cab SR5 TRD 4x4, Silver, 165k
KITEWAGON is offline   Reply With Quote
Old January 15th, 2019, 09:46   #3
ttcheung
Fuel Economy: 40mpg
In slightly warmer temps (40s-50s) the needle will go to the mid point. 495 also has some inclines and declines, and I'm sure coasting cools the temps a lot. During regen mode that temp needle will climb to the middle as well. Therefore I hope my powertrain's alright.
People have been talking about fuel economy improvements; is it from the aerodynamics?, or from quicker warm-up times?
1995 300ZX 2+0
Old January 21st, 2019, 15:26   #4
GTiTDi
Macht Schnell! Vendor
GTiTDi's Avatar
Location: 3 Spruce st Wareham, gateway to Cape Cod Massachusetts
you may need a new thermostat.
91 GTI CJAA (was 1Z powered) (2012 TDIfest Radical class winner) CTN+(eurotuning 6th) fully deleted, 3" SS downpipe and side pipe running standalone using the Tischspiegel
MK2 GTI build
schnellsnailFB
GTiTDi is offline   Reply With Quote
Old January 22nd, 2019, 15:33   #5
Matt927
Matt927's Avatar
TDI(s): several
Yes. Lower Grille.
Around 165 actual coolant temp will indicate 190 on the dummy gauge.
Matt927 is offline   Reply With Quote
Old January 22nd, 2019, 18:29   #6
Fahrvegnugen
Yes I use 1/2 inch dark grey pipe insulation and it helps keep the engine bay warm. Cruising on the highway without it I sometimes can drive long distances without being at operating temp. You just have to take it off once itís above freezing.
http://forums.tdiclub.com/showthread.php?t=160835
Fahrvegnugen is offline   Reply With Quote
Old January 22nd, 2019, 20:35   #7
jackbombay
jackbombay's Avatar
TDI(s): A4 Jetta
Fuel Economy: 57/43/32
For a while I had a very consistent commute, 14 miles one way, 50 MPh, one stop light, and never any traffic of any sort. with temps typically in the single digits in the am and teens to mid 20's in the pm my winter front and intercooler cover gained me 2 MPG, PLUS the car warmed up in about half the time. I drove the commute as consistently a possible, on the cruise at 50 the whole time except for a few corners that I had to slow for.
Hp vs. TQ
jackbombay is offline   Reply With Quote
Old January 23rd, 2019, 06:42   #8
Slurry Pumper
I commute about 1-1/2 hours down the PA turnpike, and yes I block the grill with the 1/2" pipe insulation jammed in every place I can jam it in. The difference is noticeable with quicker heat up times. As you probably should know starting the TDI up and letting it idle in an effort to heat up the car is useless, but the car now will heat up pretty well within a few miles of driving when without the grill blockage, sometimes like the other day when it was 5 degrees outside the temp may never get to the operating temp. You also get better winter mileage.
Jumping from one slurry hole to another slurry hole in an effort to drain all the holes I can.
No hole to big, no head to high, no fee too excessive!
Slurry Pumper is offline   Reply With Quote
Old January 24th, 2019, 13:02   #9
KAT90
KAT90's Avatar
TDI(s): 99.5 Jetta
Fuel Economy: 56 mpg
Western Mass here, commute to Hartford. I also block lower grill only with foam pipe insulation. Full engine temp reached 2-5min sooner depending on outside temp.
KAT90 is offline   Reply With Quote
Old January 27th, 2019, 12:09   #10
Powder Hound
Powder Hound's Avatar
Pipe insulation isn't usually noticeable unless you point it out to someone. It holds in place, it is easily replaceable if lost or damaged, low cost - what's not to like?
I've left mine in place until I started to wonder on 70+ degree days if I would overheat, but I never have. Maybe on a day that warm if your fans failed it would, but if everything works, no problem. (Not that I recommend leaving it in there that long!)
Cheers,
PH
Old January 28th, 2019, 20:23   #11
Metal Man
Metal Man's Avatar
So "this guy I know" had his rad blocked on his 06 Jetta last year. This car doesn't get used every day so things can get forgotten. So "this guy" took the Jetta on a trip to Jersey on the interstate. On the way back the temps are starting to get into the high 80's and the speeds are almost that high. He starts to wonder if he every unblocked the rad so he pulls over to check and sure enough it's all blocked off. Switched from A/C on to windows down and heat on high for the rest of the trip with no issues.
For parts and timing belt tool rentals www.metalmanparts.com FREE shipping on most orders over $75.
Metalmanparts Facebook page
https://www.facebook.com/metalmanparts
Metal Man is offline   Reply With Quote
Old February 7th, 2019, 13:46   #12
ttcheung
Fuel Economy: 40mpg
I bought some pipe insulation from the local hardware store and stuffed the lower grille with them. I didn't do a perfect job, so there's small openings on each end.
The warmup times definitely improve, and with temps either in the 20-30s, the needle rarely hits midpoint, unless I drive her harder, or that it's in regen mode.
I hate how the car's caked with salt.
1995 300ZX 2+0
Old March 18th, 2019, 11:07   #13
RideoutKSC
Default Grill Blocking
I've been blocking my grill for five years with the same pieces of foam pipe insulation. I make the trek on 495 from exit 52 in Haverhill all the way to Exit 37 in Billerica/Lowell/Tewksbury or wherever that exit drops me off. My warmup times increased significantly after I put the foam in. Nobody really notices it, and it stays put when I go through car washes.
RideoutKSC is offline   Reply With Quote
My homemade winter grille cover! PeteZ06 Audi A3 69 January 12th, 2016 08:32
Winter Grille Cover PeteZ06 VW MKV-A5 Golf/Jettas 8 December 11th, 2015 15:21
lower grille block steve05ram360 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 3 January 26th, 2014 10:05
Can I block part of my grille? Ernie Rogers TDI Fuel Economy 2 August 24th, 2005 11:57
? for all who block grille in winter Hamsterdiesel VW MKIV-A4 TDIs (VE and PD) 1 November 21st, 2002 17:58
Page generated in 0.16988 seconds with 11 queries
[Output: 114.98 Kb. compressed to 96.26 Kb. by saving 18.72 Kb. (16.28%)]
