Q7 noise coming from throttle valve
farmerrae
Ohio
Passat, Jetta
My 2015 Q7 TDI with 40,000 miles. Just recently it started making an engine noise that when investigate, appears to be coming from the throttle valve. It's a whiney-humming-type noise - like from low power steering fluid. Doesn't happen immediately - but when it starts, it slows down at idle and picks up when you rev it up. Any suggestions - solutions - thoughts? (FYI - VW Audi/emissions has been performed. Never noticed it prior to the fix and haven't driven many miles since the fix.)
