Old January 7th, 2019, 15:58   #1
GD
GD's Avatar
Default Creaky after Gen 1 Fix Advice
After driving the 2014 Jetta after the Gen 1 Fix however I noticed a creaky scraping scratching noise at the front end when going over speed humps.
Also the foil pouch under the middle of the car seems to be a little lower then the rest of the car.
Anyone else notice this in their fixed cars?
dealer says if it isn't related to the Emissions Fix they will charge a diagnostic fee.
Is the plastic skid plate/side skirts removed for the Gen 1 Fix?
TDI'ers Do it Better!
2007 Benz ML320 CDI too many toys to list
2011 Jetta TDI (CJAA) Highline DSG Reflex Silver 165,000 kms
2004 Jetta TDI PD (BEW) Platinum Metallic Grey 340,000 kms SOLD
2000 Jetta TDI ALH Black 398,000 kms, TT LCA Bushings, TB changed at Windex GTG SOLD
GD is online now   Reply With Quote
Old January 8th, 2019, 05:48   #2
740GLE
belly pan for sure, heat sheilds are also removed for ease of access as well. I think the mk6 jetta (non golf based) is more labor intensive than other platforms.
Old January 8th, 2019, 15:46   #3
GD
GD's Avatar
Good to know about the heat shields as this noise only appeared after the recall was done. Its definitely not the sway bar links as they were done.
Appears to be a Fix for Gen 1 cars! Gen 2-3 are Software. BleachedBora Dieselgate - VW Group Emission Scandal 592 October 12th, 2017 10:46
Gen 2 vs Gen 3 after emissions fix? Rick_Brown Dieselgate - VW Group Emission Scandal 4 September 20th, 2017 13:35
Now that the Gen 1 fix is out: Contemplating the Gen 3 for Gen 1 swap toneman Dieselgate - VW Group Emission Scandal 50 August 20th, 2017 22:48
Will switching back to amber brake fluid fix a creaky clutch? shouck VW MKIV-A4 TDIs (VE and PD) 6 October 1st, 2009 10:22
Page generated in 0.11966 seconds with 11 queries
[Output: 58.91 Kb. compressed to 53.22 Kb. by saving 5.69 Kb. (9.66%)]
