Old December 27th, 2018, 19:19   #1
vwztips
vwztips's Avatar
Default Radio code issue
Not sure where to post this and a search didn't provide anything.
I needed a radio code for a Monsoon head unit for a B5.5 Passat, so I called my buddy at the dealer and his normal access point for radio codes was grayed out on the screen. So he could not get a code. Neither could the service guy. I took the car to the dealer and the service tech could not pull a code through the system from Germany.
The dealer finally said that VW quit supporting these codes for the radios (as of last week). I even tried getting a code for a radio from a 2011 Jetta and they could not get that.
Anybody know another route to get codes, or do I have some electronic bricks now?
vwztips is offline   Reply With Quote
Old December 27th, 2018, 22:23   #2
DeliveryValve
I don't have any first hand experience with this site but it looks promising.
https://www.onlineradiocodes.co.uk/v...at-radio-codes
Or perhaps this site..
https://www.vwcodes.org/vwcodes/
- Richard-
2005 Passat TDI GLS Wagon 21x,xxx miles - Chainless
DeliveryValve is offline   Reply With Quote
Old December 28th, 2018, 04:04   #3
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Wow, that is annoying. I wonder if they no longer do exchanges on these radios either?
oilhammer
www.cardocautomotive.com
Old December 28th, 2018, 12:38   #4
vwztips
vwztips's Avatar
I asked and the exchange program is a new radio cost $250 - $650 depending on the radio, haha
He was serious too
Old December 28th, 2018, 13:09   #5
oilhammer
oilhammer's Avatar
$250 isn't bad. $650 is dumb.
I bought all the Clarion made units they had left years ago for my 1991 Jetta. I now have spares. They were $25 each.
oilhammer
Old December 28th, 2018, 13:10   #6
QuickTD
Last time I needed a radio code it was a struggle. Seems they can't just key in the radio serial number and get a code anymore. They have to have the car hooked up and the code is delivered via ODIS without the operator being able to see it. Seems similar to how the PIN key coding system changed a few years back.
I was still able to get the code though.
QuickTD is offline   Reply With Quote
Old December 28th, 2018, 19:45   #7
vwztips
vwztips's Avatar
Tried that too but the tech could not pull it out of the system
Old December 30th, 2018, 15:47   #8
vwztips
vwztips's Avatar
Hey DV, thanks for the links. I used the second one. I got the code for the Navigation unit from my 2011 Jetta for $22. Much easier and faster than the dealer for $50 that couldn't get it at all!
Old December 31st, 2018, 13:26   #9
PickleRick
PickleRick's Avatar
Would another radio help you? I believe i have 2 different monsoons from 04/05 you can have. These are not exactly hot sellers so id eventually toss them anyway.
Nobody exists on purpose. Nobody belongs anywhere. We’re all going to die. Come watch TV.
PickleRick is offline   Reply With Quote
Old December 31st, 2018, 14:26   #10
vwztips
vwztips's Avatar
Not really, but thanks. Just needed the code. If u have the codes for those, write it on the unit
Old December 31st, 2018, 18:34   #11
PickleRick
PickleRick's Avatar
No idea where id find the codes. I use a pioneer head unit.
Old December 31st, 2018, 18:59   #12
tdi-mb
I used the second site above(vwcodes.org) just last week with success.
I had two tdi's - one we did the fix on(2010 JSW) and one we did the buyback(2013 Golf). The Golf had a better radio so I swapped them(along with the bluetooth modules under the passenger seat) before returning the Golf. Tried several dealers to get the keys for free, including the one I bought the JSW from back in 2010 but no luck with any of them - they all wanted to send me to service who wanted to scan it and invoice it.
So, I send vwcodes.org $12.99 via paypal and less than a day later, I had my code which worked no problem.
tdi-mb is offline   Reply With Quote
Old January 2nd, 2019, 10:52   #13
imo000
imo000's Avatar
Fuel Economy: Good enough
If you still have the original user's manual folder that came with that car, it should be in there there somewhere.
imo000 is offline   Reply With Quote
Old January 5th, 2019, 20:56   #14
DeliveryValve
Good to know it worked out. But I thought it was $12.99?
- Richard-
Old January 5th, 2019, 21:52   #15
vwztips
vwztips's Avatar
It is for a non-navigation radio. I did both kinds. Without nav is $12.99. With was $22.99
Radio Issue Squamish_TDI TDI 101 1 April 24th, 2018 14:07
'01 Monsoon radio: code needed after power-off? or does the radio recognize the car? verylongdrive VW MKIV-A4 TDIs (VE and PD) 8 January 29th, 2018 15:42
Replaced OEM Radio, same radio code or not? SFHGolfTDI VW MKIV-A4 TDIs (VE and PD) 10 August 15th, 2011 07:16
Where is radio code stored? - radio body and/or faceplate? 02AutoWag TDI 101 9 March 7th, 2007 12:45
HOW do i code radio - i have code, need proceedure geekIM VW MKIV-A4 TDIs (VE and PD) 7 November 16th, 2002 20:48
Page generated in 0.16508 seconds with 11 queries
[Output: 125.88 Kb. compressed to 104.58 Kb. by saving 21.30 Kb. (16.92%)]
