Old December 18th, 2018, 16:27   #1
ZiggyoftheNorth
Default Newer factory shark fin antenna on MKIV Jetta
I took a shark fin off a 2008 or 2010 Passat. It has two wires. One is black and I believe is the radio antenna. The other is gray and I think it is navigation. Mine has a single black wire. I don't have navigation or OnStar. I assume I need to connect the black wire to my black wire but the connectors are different. If this was a single wire it would be easy, but I appears to be a small diameter coaxial cable. Would a newer car without navigation have the same connector as mine or is there some sort of adaptor I can get?
ZiggyoftheNorth is offline   Reply With Quote
Old December 20th, 2018, 04:21   #2
bobbiemartin
It may not have a radio antenna. Not sure on the Passats, but lots of VWs with shark fins have the radio antenna in the rear glass. Shark fin antennas include navi, satellite radio and cell for OnStar. This chart may help determine what you have.
bobbiemartin is offline   Reply With Quote
Old December 20th, 2018, 06:14   #3
ZiggyoftheNorth
Thanks. I'll have to compare the key part when I get home. It has Black which is radio's color. It also looks like they sell various adaptors too and if not too costly that may be the way to go.
Old December 26th, 2018, 19:48   #4
JettaTDIBlack
Fuel Economy: 38.88mpg/City Not tested, yet/Highway
Does a third party make one of these with all of these features plus work for HD/Radio that fits a MK4?
Sent from my LGMP260 using Tapatalk
JettaTDIBlack is offline   Reply With Quote
Old December 31st, 2018, 07:03   #5
ZiggyoftheNorth
I found a VW/Audi radio antenna to Fakra adapter on Amazon. Couldn't tell much from the photos but the description sounded right and it was cheap so I ordered it. I'll post the results.
Old January 3rd, 2019, 09:45   #6
JettaTDIBlack
Any news? I'll eventually replace the stock single din factory radio with an aftermarket two din radio.
dubrs.com
Old January 3rd, 2019, 19:44   #7
ZiggyoftheNorth
This is what I ordered. I got it today but haven't had a chance to se if it fits. It looks like it is Fakra to standard coax like on an American car. I may need another adaptor.
https://www.amazon.com/KYLIN-ANTENNA...236_SY340_QL65
Old January 7th, 2019, 17:04   #8
turbovan+tdi
turbovan+tdi's Avatar
Our cars don't like shark fin, I've tried a few, including OEM MK5/6, made my own adapters, reception isn't the greatest. Let me know how that booster works out.
Old January 9th, 2019, 08:52   #9
ZiggyoftheNorth
So far, it looks like my adapter needs an adaptor. The Fakra ends are both male. Thinking of hunting down connectors and making my own.
Old January 9th, 2019, 12:59   #10
SilverGhost
SilverGhost's Avatar
One of the only (later model cars) shark fin roof antennas to have AM/FM radio is the Tiguan. Most of the rest have AM/FM in the side and/or rear glass. And Tiguan was available with Nav and CarNet, so possible to get AM/FM, GPS, Cell, and Sirius.
Jason
SilverGhost is offline   Reply With Quote
Old January 9th, 2019, 13:02   #11
SilverGhost
That is to install aftermarket radio into car with diversity antenna system with multiple antennas (W8 Passat or later MkV, MkVI)
Jason
Old January 9th, 2019, 13:10   #12
bobbiemartin
My 2012 Tiguan had a dummy (empty) shark fin antenna. The AM/FM antenna is in the back glass. I installed a factory satellite/navi radio, so I changed the shark fin to an antenna for those but kept the glass antenna for the radio signals.
Old January 9th, 2019, 17:36   #13
ZiggyoftheNorth
I grabbed the antenna from a MK5. Mine is a MK4 and as far as I know there is no option for an antenna in the glass on mine. The seller of the adaptor has some explanation of the shark fin switching between channels to maintain a constant signal. I'm not sure if a MK5 is set up that way or has an antenna in the glass.
I realize it is for radio installation, but expected it to plug in at the shark fin the same as it would under the dash. I hoped the coax would match VW, but didn't
I can try grabbing the wiring from the antenna to the dash. I think adaptors may be easier though.
Old January 11th, 2019, 11:08   #14
SilverGhost
I have a 2009 Tiguan with the whip antenna and no antenna in the glass. It does seem to vary by year, but also by equipment. I have seen a very few base models with a MkIV whip antenna. And I have seen loaded cars that have antennas like yours.
Jason
Old January 11th, 2019, 11:20   #15
SilverGhost
Sorry, I should have been more clear. That adapter goes under the dash to hook up an aftermarket radio to stock antenna, and power up the stock signal amplifier in the antenna.
Main difference on the FARKA connectors is index tabs. Colors indicate function. Tan or white is AM/FM, green is SDARS (SiriusXM), blue is GPS, and I think purple is GSM (cellular). I think the repair connector is grey and has no index tabs.
The diversity antenna does basically what the seller says, but not the shark fin. Generally the system works with multiple antennas. Either in back side windows (one on each side) or rear window (antenna connection on both sides meaning two antenna grids). The only thing the shark fin or whip antenna could do is filter out signal reflections (like off tall buildings).
Kufatec does antanna adaptors.
Jason
Shark Fin antenna ApriliaNut VW MKIII-A3/B4 TDIs 4 May 6th, 2013 14:32
WTB 2006 Jetta Shark Fin antenna psd1 Private TDI Items for Sale/Wanted 0 December 29th, 2012 11:20
2009 Jetta Shark fin antenna rotorhead23 VW MKV-A5 Golf/Jettas 6 July 2nd, 2010 18:51
shark fin antenna TXRanger83 VW MKV-A5 Golf/Jettas 12 February 4th, 2010 06:14
Shark fin styled antenna Concat Upgrades (non TDI Engine related) 5 November 13th, 2009 21:11
Page generated in 0.17528 seconds with 11 queries
[Output: 131.09 Kb. compressed to 110.42 Kb. by saving 20.66 Kb. (15.76%)]
