Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Audi SUVs (Q7 & Q5) and other V6 TDIs
Audi SUVs (Q7 & Q5) and other V6 TDIs Discussions area for Audi Q7 and Q5 TDI (2009+ in Canada & the US) as well as others with the V6 TDI such as the A6, A7 and A8 sedans.
Old December 10th, 2018, 09:23   #1
seancashmere
Default 2016 Q5 Fuel Filter replacement tutorial?
Anyone have a link to a how-to for swapping out the fuel filter on these cars? It looks like the part is an inline fuel filter. Will I need a special tool to do this work? Where is it located? Any photos?
Oddly, I can't find anything when I Google it. Thanks in advance.
seancashmere is offline   Reply With Quote
Old December 10th, 2018, 09:39   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Under the right (passenger) side of car, you'll need to remove the shield underneath... against the unibody rail.
Out in the open once the shield is dropped, two clamps, kinda sits in a little bracket than needs to be taken loose first. It is pretty self explanatory once you see it. Have a drip pan ready.
oilhammer
www.cardocautomotive.com
Old December 10th, 2018, 09:47   #3
seancashmere
You are a rockstar! Thanks. Do I need special pliers to loosen the lines?
Also, when you say right side, are we talking right rear near the fuel door? Mid near where front and rear door meet? Front?
Also, the shield. Torx 30? Torx 20? Phillips?
Thanks!
Old December 10th, 2018, 10:07   #4
oilhammer
oilhammer's Avatar
Midship, about half way between the axles.
Slip joint pliers for the clamps, I think the shield and bracket is just 10mm nuts.
oilhammer
Old December 10th, 2018, 10:23   #5
seancashmere
Thanks!!!
Old January 1st, 2019, 13:50   #6
Brooklin Express
does the filter need to be primed?
Brooklin Express is offline   Reply With Quote
Old January 1st, 2019, 14:41   #7
BarryT82
Yes. Prime it.
BarryT82 is offline   Reply With Quote
Old January 21st, 2019, 07:49   #8
2014 A6
If you tackle this any pics you could supply or advise about your experience to help others (me) would be appreciated! Do you use the VCDS to prime the filter?
2014 A6 is offline   Reply With Quote
Old January 31st, 2019, 09:37   #9
2014 A6
Anyone have an update on this? Or a resource where a handy fellow can get instructions? Thanks!
Old February 1st, 2019, 06:22   #10
Radman
I did not need to prime mine on my A6. Just made sure to lose as little fuel as possible by quickly swapping the filter.
It is an easy swap once you see it. Check flow direction on filter, I believe there was an arrow indicating which direction to install it in.
2014 Audi A6 TDI, Unitronic Tuned
2014 Touareg TDI, Unitronic Tuned
Radman is offline   Reply With Quote
Old February 1st, 2019, 12:21   #11
2014 A6
Thanks Radman! So the location is on the passenger side mid cabin underneath on the A6 too?
Old February 4th, 2019, 06:33   #12
Radman
Correct, it will be obvious once you remove the belly pan.
Old February 4th, 2019, 06:55   #13
2014 A6
Thanks Radman. Just got some race ramps (rr-xt-2-hd) since I’ll be servicing my Audi going forward. These things aren’t cheap but I’m still ahead after a fuel filter and oil change with what the dealer charges.
buy NOS 2016 Q5 TDI or new 2018 Q5 2.0t acktdi Audi SUVs (Q7 & Q5) and other V6 TDIs 7 February 11th, 2018 06:07
2016 Audi Q5 TDI HBarlow Audi SUVs (Q7 & Q5) and other V6 TDIs 3 January 24th, 2017 19:16
2016 Q5 TDI, I'm new to the forum. Hello everyone. djp3ehr Audi SUVs (Q7 & Q5) and other V6 TDIs 1 January 19th, 2016 20:01
'03 Jetta Wagon Intercooler replacement tutorial? Grantxvx VW MKIV-A4 TDIs (VE and PD) 2 February 11th, 2015 11:35
2016 q5 tdi vinman123 Audi SUVs (Q7 & Q5) and other V6 TDIs 0 June 3rd, 2014 16:47
Page generated in 0.15346 seconds with 11 queries
[Output: 107.32 Kb. compressed to 89.50 Kb. by saving 17.82 Kb. (16.60%)]
