Old May 10th, 2017, 17:39   #1
philshizle
Default Bsm delete and 5 speed swap advice
I have a DUK trans on the way and ordering an alh/brm bsm delete as well as a timing belt kit from Roselandtech for a relative's passat wagon. I'm looking for some advice regarding the best way to approach this project. I have shop space but no lift, engine hoist or support bar. I'm leaning towards purchasing an engine support bar that can be used with future jobs. Then taking the entire front clip off and removing the transmission and subframe. Then do the bsm delete and timing belt first before moving on to the wiring, clutch lines, and installing the new transmission.
I have a couple questions regarding this process:
Would renting an engine hoist and pulling the transmission and engine togethor be easier? Is it simply personal preference?
If I were to use the engine support bar is it worth removing the front clip? Or should I simply move it to the service position. It's my understanding that the only advantage to this is to avoid disconnecting the A/C. The atf will need to be disconnected as well but because I'm swapping the tranny that needs to be done either way, correct? That's a bit of a gray area for me in my research.
Also I have been referencing the geared module upgrade .pdf for the bsm delete process and am just looking to confirm that it is okay to completely remove the subframe when doing the delete? I wasn't able to determine any reason it couldn't be.
Thanks for the incredibly informative forum everyone.
philshizle is offline   Reply With Quote
Old May 11th, 2017, 07:14   #2
Nash_TDI
Veteran Member -TDIClub Enthusiast
Nash_TDI's Avatar
Fuel Economy: 63.25mpg max
Might as well do a cam too.
I have not done it all at once before so i typically leave it int he car and do service position or drop subframe to do a trans swap. I am doing it all like you this summer on another car and pulling engine and trans I think together out the front. I have all the hoist support bars, etc.
2.0 ALH, GTB2260, 12mm, etc, etc.....
www.nashimporters.com http://louisvillevw.org/
TDI Repair Available, TBs, Clutches, Manual Swaps, BSM, etc..
PD Cam tools, BSM tool, VE & PD TB tool rental available.
Nash_TDI is offline   Reply With Quote
Old May 11th, 2017, 09:01   #3
zzdiesel
I have just finished pulling the tranny on my passat to replace the torque converter. Previously I pulled the engine and transmission together to do the Tranny swap on my other passt as well as a BSM delete. I found I much preferred to pull the two together and do the work on the bench. You don't have to evacuate the AC, just remove the compressor and condenser and hang it aside. Main thing with this process is dealing with the wiring. With the front off it is relatively easy to pull the engine and transmission together.
zzdiesel is offline   Reply With Quote
Old May 11th, 2017, 10:12   #4
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
I did them both at the same time, and left the engine in the car. No access to a hoist. As above, just set the ac components aside. No need to evacuate the refrigerant.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old May 11th, 2017, 19:21   #5
vwztips
vwztips's Avatar
With no lift, I suggest pulling them both at the same time since you need to the delete too. That way you can easily get to all the oil pan holes as well as drill and tap the oil return hole for the delete. Just unplug the harness in the ECU housing area and lay it on the engine. Pretty straight forward process.
vwztips is offline   Reply With Quote
Old May 12th, 2017, 05:27   #6
philshizle
Thanks for the tip about the ac. So would it be worth it to rent and engine hoist then? I don't see myself needing one in the future too often.
Old May 12th, 2017, 09:06   #7
zzdiesel
Your call on the hoist. I don't know the cost but it would sure limit your under the car time.
Old May 12th, 2017, 12:39   #8
stamp11127
Don't know about you young guys but laying on a good creeper does have a few advantages for us ol timers.
There is a current thread on here where a member did pull both together and lost throttle response when cold after reassembly. Since his issue hasn't been resolved to this date I would consider pulling the trans by itself.
http://www.forums.tdiclub.com/showthread.php?t=470498
Teaching Basic Electrical & Electronics.
stamp11127 is offline   Reply With Quote
Old May 12th, 2017, 17:53   #9
QuickTD
I think that's a stretch. I've had lots of them out pulling as a unit, no problems to report. I can have the engine/trans out in a couple hours. Much easier to work on this way. It's the only way I'd do a manual swap.
QuickTD is offline   Reply With Quote
Old May 15th, 2017, 13:30   #10
vwztips
vwztips's Avatar
/\ditto/\
Old May 16th, 2017, 05:40   #11
Nash_TDI
Nash_TDI's Avatar
I dropped the motor too much one time and pulled out the vac line to the brake booster, but only thing I've ever ran into.
Old May 16th, 2017, 09:16   #12
mgoff5000
Fuel Economy: 45 Jetta, 30 Passat (MPG)
As someone who did the BSM delete with the engine supported from above, I envy everyone showing pics working on the same job with the engine out.
Not to mention getting to do the tandem/pump and coolant flange with that kind of space..nice. Not an option in my garage/household but if I could I'd consider it.
mgoff5000 is offline   Reply With Quote
Old May 17th, 2017, 05:23   #13
philshizle
Thanks for the input everyone. I'm going to find an engine hoist and will pulling it out with the front end off. I don't feel like buying a transmission jack or bench pressing the auto out. I'm still a little unsure if I need tool T10255 to do the delete. I see it is necessary for the geared module install just wasn't sure if I needed when going with the alh oil pump. Any other recommended tools? I'll be using and air hammer for the crankshaft sprocket and will be fabing a tool to counter hold the sprocket when loosening the crankshaft bolt. I have the pd timing belt tool kit and vcds on the way. Anything I'm missing?
Old May 17th, 2017, 06:13   #14
QuickTD
I haven't even heard of tool T10255, so you don't need it.
Old May 17th, 2017, 09:52   #15
philshizle
Good enough for me, thanks!
I think I saw it in the geared balance shaft module pdf by oil oilhamer and mogolf
BSM delete silicondt VW MKV-A5 Golf/Jettas 6 February 19th, 2015 13:25
bsm delete cb1 VW B5 Passat TDIs 1 May 8th, 2013 19:36
Quandry: BSM Delete + 5spd swap vs. BSM Gear + Tq. Converter sirpuddingfoot VW B5 Passat TDIs 17 November 1st, 2012 18:27
re-chain instead of BSM delete RSMS VW B5 Passat TDIs 78 October 18th, 2012 11:44
Page generated in 0.16248 seconds with 11 queries
[Output: 125.55 Kb. compressed to 104.61 Kb. by saving 20.94 Kb. (16.68%)]
