Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > West Coast Canada/USA
West Coast Canada/USA Local discussions for those on the West Coast of Canada and the US.
Old April 12th, 2018, 09:25   #46
KDG
Also passed smog, no problems, with RC2 and EGR setting mods, in Santa Cruz area.
KDG
Used to own: '03 Jetta TDI 5-speed running on HPR diesel, RC2, PP520s, Eibach Pro Springs/Shocks, BBS RXIIs, Evolution Skid Plate
KDG is offline   Reply With Quote
Old May 20th, 2018, 22:35   #47
bati
TDI(s): jetta
i FAILED smog this weekend all monitors were set on the car. The car passed visual inspection
but when the smog tech select to printed the report the computer said DATA FAIL and i have to go
to a state referee.
bati is offline   Reply With Quote
Old June 5th, 2018, 11:56   #48
tomotdi
Those in Sonoma County may consider Cheap Smog Test on Petaluma Hill Road in Santa Rosa. They performed a pre-check on my 03 TDI wagon At no charge, and found out that the CEL for a recent glow plug failure, corrected, was still hiding in the computer. Once I had driven the car far enough, another free pre-check to confirm that the fault code had cleared completely. Car passed with Malone stage 1.5 in place. $38 out the door with online coupon. Great place!
tomotdi is offline   Reply With Quote
Old December 17th, 2018, 22:55   #49
Soupinmycoupe
Soupinmycoupe's Avatar
Fuel Economy: 46-51mpgs
Good to know, Iím in Coffey Park!
Matt Phelan;Matt-98AHU NORCAL's BEST TDi guru.
Email Matt
Soupinmycoupe is offline   Reply With Quote
Old December 20th, 2018, 12:24   #50
aslspiderman
aslspiderman's Avatar
TDI(s): 98 Jetta
Fuel Economy: Really good!
Default EGR readiness failed/incomplete
So--I just had some work done on my 98 by Matt(big shout-out to a fantastic Guru!) and he told me that my egr readiness monitor would not set. I had this problem last time I had this smogged(1 1/2 yrs ago) and a new MAF "fixed" the problem.
Fast forward to now and the little gremlin is back. In Sept 2019 it will be due for another smog. Matt seems to think that it is my tune. Unfortunately I have no history on it as I purchased the car the with the current tune. I suspect the tune also.
Everything appears to be functioning properly and the car runs great. (BTW I love the current tune). Before I spend money on another tune that I know will set that readiness monitor, I just want to throw it out to the TDI community: is there anything else to check to rule out anything but the tune?
98 Jetta, K03/04, 520 sprints, aligator chip, SRS, torsion bar, Billy HD's, TT bushings VR6 clutch, GLX seats
aslspiderman is offline   Reply With Quote
Old December 20th, 2018, 17:37   #51
dlai
dlai's Avatar
Fuel Economy: Up There
Listen to Matt. If he says it's the tune, it's the tune. You already had your answer. Have Matt retune it, pass smog, end of story...
2002 Golf, 2005 Passat Wagon Stonehenge Gray
Chainless Since 4/22/09
dlai is offline   Reply With Quote
Old December 22nd, 2018, 10:25   #52
aslspiderman
TDI(s): 98 Jetta
Thanks for your input dlai. That is no doubt my eventual plan. I just wanted to throw the question out there because I really like the tune that I have, whatever it is. At one point I think someone said it might be an alligator tune. I just didn't want to spend the money if I don't need to.
Of course then I start thinking about larger injectors, and the rabbit hole just gets deeper
2005 Golf fail CA smog test jaysonl76 TDI (Diesel) Emissions 0 August 24th, 2016 08:41
CA Smog FAIL after 5spd swap/tune wulferus VW B5 Passat TDIs 17 July 30th, 2016 21:34
check engine light and CA smog new/used golf 2006 TDI 101 4 May 27th, 2016 15:03
HELP! Check engine light is not visible...failing CA smog check. redscare TDI 101 3 April 4th, 2011 21:20
CA smog check ?..........EGR readiness invader TDI (Diesel) Emissions 6 April 3rd, 2011 11:22
Page generated in 0.13616 seconds with 11 queries
[Output: 84.49 Kb. compressed to 73.55 Kb. by saving 10.94 Kb. (12.95%)]
