Old February 19th, 2017, 18:43   #31
algirdas
algirdas's Avatar
TDI(s): 98 jetta AHU
All the right mods! That'll be a fun ride
98JettAHU, K03/4hybrid, RC3+, HifloX216, ColtStg2cam, PD130intake, Westach EGT&Boost, Mk4/O2Jshifter/selector, 5lug conv, TT12.3rotors, 11"rear disc, SBC-Stg2End, OBX-LSD,
algirdas is offline   Reply With Quote
Old February 19th, 2017, 23:00   #32
bbarbulo
i spy a shiny new short shifter too?
FOR SALE!!00 TDI Golf 5spd, satin silver GTI tails w/ 5 light brake mod 20AE springs Bilstein SS shocks 17 Long Beach Altas skid plate clear repeaters short antenna Clarion deck G60/VR6 clutch
bbarbulo is offline   Reply With Quote
Old February 20th, 2017, 04:13   #33
bobbiemartin
Yes, I mentioned it in post#16. It's a short throw part from a Golf R.
bobbiemartin is offline   Reply With Quote
Old April 20th, 2017, 19:05   #34
bobbiemartin
It's been a while but I'm still working on the Golf.
I installed new Cupra R rear bushings (6LL 501 541) it was easier to remove the rear axle. Not an easy or fun job! It's back in place with new brake pads & rotors to match the front. Also got Shine Racing Real Street Springs and Bilstein TC shocks.
Installed a PD Lift Pump
and a 2.5” stainless steel downpipe & tailpipe
Still sorting out the PD150 vent pipe, I think I have a solution. It actually runs now, in fact I drove it around the block last week.
One thing I did was to have a flexible line installed on the power steering hose. They cut the steel line and welded on AN fittings. Then made a hose with AN hose ends to connect the metal pipes. Makes running the PS hose around the 6 speed a lot easier. The clamp is on a 1.5” tall standoff bolted to the transmission mount. I like it a lot better than trying to bend a 5 speed hose to fit.
And here it is off the jack stands! The wheels are powder coated Force with 205/55 16 Yokohama S Drive tires. Haven't installed the wheel centers yet or even cleaned them up from mounting them. Started on the interior, the headliner is out at the upholstery shop.
Old April 25th, 2017, 12:39   #35
bobbiemartin
Another busy weekend, but not much to show. I got all the black interior parts from a parts car. Stripped out the interior of the Golf. It's probably good to good clean every 15 years or so!
Interior all out. After this pic was taken, I put the black carpet in along with a few interior bits.
Installed a vented fender liner from a Jetta City.
Got a few little things to do, then it's off to another body shop to fix the paint on the top while the headliner is out. The first body shop couldn't seem to get it right after taking a month. Unfortunately State Farm is refusing to pay for redoing the paint, even though they are supposed to have a "lifetime" guarantee. Oh well. I've also ordered a new front bumper. The original one is cracked so I'll have that painted as well.
Old July 25th, 2017, 08:58   #36
artdeco42
Any more updates? How are you liking the 6-speed?
artdeco42 is offline   Reply With Quote
Old July 25th, 2017, 14:18   #37
bobbiemartin
Talking
It's been busy but I have made more progress. I'll try and post more soon. We sold both MK4 wagons and bought a 2015 GSW - not in that order though! Which means I'm driving the Golf now as my daily driver as I finish it up. The mechanical stuff is about done, along with the paint but the interior has a ways to go.
As to the 6 speed, yes I do like it. I had a 6 speed in one of the wagons I just sold, so I've been driving a 6 speed for a while now. I really like it, having the extra gear is very nice. After having both a 5 and 6 speed, I can say I would be very reluctant to go back to a 5 speed. The PD150 DMF clutch is very smooth and easy to drive. With the Peloquin LSD you can get on the power sooner out of a turn. It takes a bit different technique and I really haven't got it 100%, but there is certainly a difference to the open diff. I set the front camber at stock Golf settings. Once I get everything done, I'm going to dial in some more front camber, I think that will help. Then I'll see if I need a rear sway bar. However, it has pretty good grip now.
All in all, I'm happy with the mods. It has good power (never enough, but it's OK for now), handles and drives well. It's a little louder than I would like and has a drone at speed. Once the interior is done I'm sure it will quiet down, if not enough I'll sort that out as well.
Old July 27th, 2017, 06:54   #38
artdeco42
Thanks for the update, I'm glad it's still going good on the upgrade. That GSW sound like a lot of fun too!
I'm going to be starting on updating my 2003 golf tdi this fall. I have the 6-speed and the conversion kit ready to go, but I want to do the shift fork fix before I put it in the car. I have to buy a bunch of tools too, I only have the basics at this point.
Old July 30th, 2017, 18:00   #39
bobbiemartin
I discovered my aluminum upper intercooler pipe was hitting the power steering pulley. It has good clearance, so I guess the engine is moving a bit.
I've installed a Nicktane filter in place of the stock fuel filter.
It didn't go all the way through - but it's close! I'll probably have it tig welded up and should be OK.
I've ordered a set of Vibra Technics dogbone bushings. Hopefully they will reduce the engine rocking but won't transmit too much vibration. I guess I'll find out!
I installed the stock pipe from the IC to the intake. This pipe fits better and really I don't think it's all that restrictive.
I'll see how it does, but if I don't notice much difference, I just may keep it. I like the stock appearing engine compartment as well.
I'm not 100% decided on the crankcase vent hose. The way I have it now works, but I'll probably do something else later. I'm still considering a Mann Pro Vent at some point.
Old July 31st, 2017, 08:58   #40
artdeco42
Wow, I didn't realize the engine could move enough to hit that pipe. Good to know though, one more thing to check on. The upgrade is looking good !
Old August 2nd, 2017, 05:25   #41
rocketeer928
rocketeer928's Avatar
Lots of nice work; looking good!
2003 Jetta GLS TDI with RocketChip RC5-ASV-Euro tune specific to my performance modifications - Platinum Gray
yo
1970 VW Type 3 Squareback - Cobalt Blue (Birdie)
rocketeer928 is offline   Reply With Quote
Old August 4th, 2017, 16:56   #42
bobbiemartin
I've got another project that will take the next few weekends, but I managed to get a new windshield and a rain sensing mirror installed. It works great.
The mirror is auto dimming and has the red "ambiance" LEDs that shine down.
And while the headliner is out, I resealed all the sunroof drains. I had a small drip from the left front one, but no more. We have had some good storms, but all is dry inside!
Old August 6th, 2017, 07:10   #43
GIDDY_UP_GO
Fuel Economy: 39mpg (But I drive 80mph alot!)
Where did you find the vented inner fender liner and how much was it? Thanks!
Awesome work by the way!
2010 Jetta 160K mi (Fix Completed 12/17)
2013 Beetle Convertible 70K mi
2015 Jetta TDI 40K mi (Did the buyback on 2/17)
2015 Golf SportWagen 12K mi
THIS WILL MAKE YOU CRY!
GIDDY_UP_GO is offline   Reply With Quote
Old August 6th, 2017, 07:18   #44
NarfBLAST
NarfBLAST's Avatar
Fuel Economy: 5.8 - 4.5 (40 - 52)
OEM part number is 1JM809962A which you can find at your local dealer or many places online such as here: http://www.idparts.com/vented-fender...a4-p-1063.html
- Paul
2001 VW Golf Naturally Aspirated Direct Injection Diesel 5MT 620,000 km
With 1.5" lift / Valeo G60/VR6 SMF /
Sprint 520's / RC3 / sweet turbo delete
The NARFmobile blog / push button ignition / thrustmaster shifter / http://youtube.com/narfblast
NarfBLAST is offline   Reply With Quote
Old August 28th, 2017, 18:57   #45
bobbiemartin
Default Vibra Technics Dogbone insert
I installed a Vibra Technics dog bone bush and insert. They are nicely made pieces. I went with the Vibra Technics because I prefer rubber to polyurethane for mounts. You reuse the aluminum mount, replacing only the original rubber ends. It is adjustable, but I can tell you the firm is just that. It transmits a lot of vibration to the car. The "comfort" is much better. Still a little vibration at idle, but not too bad. It does seem to help with the engine rocking, the car feels firmer when accelerating to getting off the power. I would say it is a worthwhile upgrade.
The stock mount is on the left. The middle is the small end bush. On the right is the finished mount, ready for installation. The black support brace mounts to a machined step on the small bush. You can see the step in the center picture.
upgrading sound system in '04 Golf TDI GL? kpl1228 Upgrades (non TDI Engine related) 1 June 1st, 2014 19:44
A little helpful info upgrading an 04 golf LakotaBlues TDI Power Enhancements 4 November 24th, 2010 21:02
Parting out my 2001 TDI Golf 2001 shakes347 Private TDI Items for Sale/Wanted 15 May 3rd, 2010 16:43
Mk2 Golf Country AHU TDi Upgrading to VNT caddytdi TDI Power Enhancements 0 October 18th, 2009 06:30
Upgrading my MkV Golf Speakers (UK) Hora Upgrades (non TDI Engine related) 0 May 31st, 2006 04:14
Page generated in 0.20690 seconds with 11 queries
[Output: 135.49 Kb. compressed to 114.06 Kb. by saving 21.43 Kb. (15.82%)]
