Old December 26th, 2018, 13:15   #481
Mike in Anchorage
Mike in Anchorage's Avatar
Originally Posted by sprstu View Post
2015 GSW 6spd 64K miles, MANY small annoyances
Investigating a cold temp clicking in the front suspension, probably sway bar end link but annoying this early in its life
Investigating rear wheel bearing noise at slow speed around corners (think roundabout)
Investigating clunking from rear suspension on speed bumps
Clutch slipping under heavy load in 4-5-6th gear. Must always shift down to get above 3K rpm to avoid slipping.
Driver window auto up-down 50% functioning
Radio forgets station upon start up and goes back to static 50% of the time
Tire pressure monitor system thinks tires are low, investigating reveals the system is wrong
Torn 2 outer CV boots, driver side, car is OEM height
Back up camera is 50% function, many times just black screen
*As much as I hate to recommend it, have you taken it to the dealer, in particular with respect to clutch slippage?
*Window regulator should also be covered under warranty.
*TPMS - you can reset. Have you done that at a low enough temp to keep it from alarming again?
*Radio - no idea. Do you use bluetooth for your phone? Does it function the same whether or not your phone is BT enabled?
Best wishes for the new year.
~ I'm selfish, impatient and a little insecure. I make mistakes, I am out of control and at times hard to handle. But if you can't handle me at my worst, then you sure as hell don't deserve me at my best. Marilyn Monroe
2015 Tornado Red Golf TDI Sportwagen SE, new on 2 SEP 2017, DSG, big sunroof. Lovin it!
Mike in Anchorage is offline   Reply With Quote
Old December 26th, 2018, 13:31   #482
Nuje
Radio going back to static is the "87.7 radio station bug". Talked about more than once here.
Torn CV boots - wow! Not sure what you're driving over, but that does seem bad.
Clutch slippage - that's not good. Take that in for sure.
Back-up camera in my car is the best of probably 20 different cars I've driven in - only time it doesn't work is if I put it in R, then go out of R to another gear, then back into R again.
Nuje is offline   Reply With Quote
Old December 27th, 2018, 06:00   #483
MiniAustinMini
I have been rather disappointed with the MK7 quality overall. My mk6 JSW with triple the miles was a more solid driving vehicle. I like the Ea288 engine more but the car itself feels inferior overall. Perhaps are I replace parts with non-OE pieces they will be superior quality but I have my doubts.
Does this happen to be the red one purchased from Hall VW this summer/fall? I was very interested, but when they started showing me pictures of it at the junkyard it came from... Its sad how some of these buybacks were treated.
Many of your gremlins could be cause by water damage/dry rot. My '15 GSW 6spd with 33k has only a squeak behind the dash to complain about. (had the peeling shift boot trim replaced the week after I bought it)
Best of luck to you. Do you have any kind of buy-back guarantee on it?
MiniAustinMini is offline   Reply With Quote
Old December 27th, 2018, 14:29   #484
adjat84th
adjat84th's Avatar
It would not surprise me if the clutch delay valve (restrictor) that's built into the bleeder unit could cause a slipping clutch after some miles.
FWIW, my MK7 has 75k miles and no crazy issues that weren't self inflicted.
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTB2260vklr, CP3, Peloquin LSD, Sachs SRE w/DMF, Fluidampr
Old December 29th, 2018, 08:05   #485
sprstu
Fuel Economy: average:42 best:48
It is a platinum grey originally from Michigan that was purchased in Minneapolis in sept 2017. It sat for a little while, 2 months, while it was in limbo being fixed but the CarFax shows a pretty quick turn around from VW buying it, fixing it and then selling it at auction.
None my issue are life ending, just very annoying.
81 Caddy 1.6TD
2015 Platimun GSW 6spd, post fix Kerma Tune
sprstu is offline   Reply With Quote
Old January 2nd, 2019, 04:54   #486
740GLE
I find I need to hold the window switch way longer than I should to initiate the auto up/down feature (1-2 seconds, where our previous MK5 and NMS it's instant), almost like there's lag in the canbus for it to register.
Hers: 2015 Passat SEL (NOS) w/ VW fix and Malone Stage 2 (low torque for DMF shudder).
Old February 20th, 2019, 18:45   #487
SyncroHead
SyncroHead's Avatar
Default 2015 GSW with 6-sp DSG and push-button start: Spontaneously Dies
My 2015 GSW with DSG transmission and push-button start was "new" in 2017 when we bought it from the dealer after having part 1 of the settlement modifications complete. Still under original warranty. Car has about 18K miles on it.
The car has spontaneously died while driving 5 times in the past 1.8 years. The first couple times, I thought it was just a fluke, but the 3rd, 4th, and now 5th time I've taken it to the dealer.
Behavior: Driving steadily along with no issues. Suddenly the engine stops running. Cost to side of road. Car is still "on", but engine is not running. Glow plug indicator is on. Pressing the brake pedal and the start button, the car cranks quickly, but will not start even after 20 seconds of cranking. Foot off brake and push the "start" button so car is completely off. Depress brake and then the start button again and car starts immediately as if there were no issue.
No fault codes are set when this happens.
Repeat this behavior for failures 2, 3, and 4 over a period of about a year. Months and thousands of miles go by between occurrences. Dealer could find no issue after 3rd time. Dealer (at VW recommendation) re-downloaded the ECU firmware (same version) to see if that would remedy the issue.
5th occurrence happened 2-16-19 at highway speed and car coasted to side of freeway. After turning car off, the car started again immediately. Upon putting car in Drive, engine dies. Wait 1 minute. Car starts again, appears normal, but dies again after putting transmission back into drive. Car towed to dealer.
At dealer, car would not start at all. Dealer found the starting battery failed the performance test and replaced the battery under warranty. I think this is probably unrelated.
Dealer's has had the car for 3 days now attempting to reproduce the issue. It continues to behave normally since replacing the battery. Planning to speak to the VW rep tomorrow.
Anyone else had a MK7 TDI spontaneously die like this and leave no codes?
Jim
SyncroHead is offline   Reply With Quote
Old February 21st, 2019, 14:24   #488
Lightflyer1
Lightflyer1's Avatar
These cars do seem to be sensitive to good voltages from my reading. The battery and/or charging system may very well be the issue. Do you know if the battery was replaced with a new one when you bought it after being "stored". What kind of driving do you do? Lots of short trips or longer drives? Do you have access to VCDS to scan for codes yourself or are you taking the dealers word? Have you measured and/or tested the battery yourself at all?
Old February 21st, 2019, 16:43   #489
SyncroHead
SyncroHead's Avatar
Thanks for engaging LightFlyer.
Issue: 2015 GSW with 6-sp DSG and push-button start: Spontaneously Dies
Q: Do you know if the battery was replaced?
A: The battery was NOT originally replaced and was nearly 2 years old when we bought it.
Q: What kind of driving do you do?
A: Commuting. Mostly 45-60 minutes each morning and 45-60 minutes each evening. Should be more than enough tine for a battery to come back up to full capacity after starting.
Q: Do you have access to VCDS to scan for codes yourself
A: Yes, but have not used it related to this issue yet.
Q: are you taking the dealers word?
A: Yes, so far I have. They appear to be earnestly searching to diagnoose.
Q: Have you measured and/or tested the battery yourself at all?
A: No. I never suspected the battery. The dealer did replace the battery with a new one this week and they are hoping this solves it. However, this happened first about a year and a half ago when the battery was much younger and several times in between then and now. Until this latest time, the battery had enough power to crank quickly and immediately start the car.
Thanks again.
Jim
Old February 21st, 2019, 17:10   #490
Lightflyer1
Maybe your battery was sulphated from the storage causing intermittent issues.
What Is Battery Sulfation?
Battery sulfation is the process of lead sulfate crystals building up on a battery cell. Sulfation will occur to some degree in every battery throughout its lifetime. However, rapid sulfation can occur with extended storage, overcharging, or undercharging of a battery. As more sulfate builds up on a battery cell, the less effective the battery becomes. Sulfation is the number one cause of early failures in lead-acid batteries, and can lead to any of the following: loss of cranking power, longer charging times, excessive heat build-up of your vehicle’s electrical system, shorter running times between charges, and ultimately shortening your battery’s life.
https://no.co/blog/diagnose-and-treat-battery-sulfation
Hopefully the new battery will fix this. I would suspect your car did have some codes and just not revealed to you for some reason. I thought replacing the battery was a requirement before sale of these cars. I scan my car every so often just to see if anything shows up. Sometimes intermittent issues will give you some warning before a complete failure happens.
Old February 22nd, 2019, 08:30   #491
SyncroHead
SyncroHead's Avatar
Thank you for helping.
On a couple cars I have that sit for long periods, I keep them trickle-charged with BatteryMINDer chargers that tout their desulfator capabilities.
You think that the battery sulfation issue could cause a car that's driving along fine, with overall voltage controlled by the alternator/regulator to spontaneously die? Then start up again as if there were no issue?
Jim
Old February 22nd, 2019, 08:35   #492
Lightflyer1
I personally have no idea, but that site seems point that it might be a possible issue. Especially if swapping the battery out fixes it. Probably a possible reason why they were all supposed to get new batteries before being sold.
Old February 22nd, 2019, 08:37   #493
kjclow
Fuel Economy: 55 max / 44 avg on beetle ~37 on JSW
Maybe the battery hit a dead area and therefore transferred no charge. I don't know if these cars will run without the battery hooked up. I've heard that the older diesels could keep running if you disconnected the battery.
2010 silver/black JSW TDI with DSG, 2017 Ram 1500 EcoDiesel
kjclow is offline   Reply With Quote
Old April 3rd, 2019, 10:05   #494
Kalevi1Poeg
Kalevi1Poeg's Avatar
Default Backup Camera Sticking
Anybody have the backup camera sticking during cold weather (temps below 10F)? A bit annoying since you can't open the hatch when this happens. Usually clears itself when the car or weather warms up - couple times this winter it was stuck for days.
Spring is almost here in NH (did get 1/2" snow this morning) - deal with it next winter.
Kalevi1Poeg is offline   Reply With Quote
Old April 5th, 2019, 15:08   #495
thundershorts
Hi syncro!
Similar problem on mine. Changed tank lift pump to latest version, its different from what was originally installed at factory. No codes from a failing lift pump other than low rail pressure. The new pump also is almost dead quiet. No further problem. Dealer will most likely not be able to replicate the intermittent failing. Since the newer pump is different, vw probably knew and re engineered it. Vw screwed me and wouldn't pay but I need reliability.
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Buying a 2006 2.5l TDI (R5) - Looking for advice on common issues? rsd VW Touareg TDIs 2 June 23rd, 2014 14:37
CV Boot Issues Common? JBell VW MKVI-A6 Jetta Sedan (~ 2011+) 5 February 15th, 2014 01:26
Common issues at 250k miles bmccrea TDI 101 9 November 6th, 2009 12:22
Lag issues common arnd 90000? What 2 tll dealr? ChadMad VW MKIV-A4 TDIs (VE and PD) 1 May 5th, 2005 18:14
(Early) New Years resolutions for my B4 TDIMeister VW MKIII-A3/B4 TDIs 4 December 23rd, 2002 06:29
Page generated in 0.19090 seconds with 11 queries
[Output: 138.94 Kb. compressed to 117.26 Kb. by saving 21.68 Kb. (15.60%)]
