Old August 26th, 2014, 06:08   #1
khenn
Fuel Economy: 48mpg for Jetta, 42 for Passat
Exclamation 2013 Passat TDI SE Acceleration Safety Concern
Hi, I have a 2000 Jetta TDI with just over 413,000 miles and we just purchased a new 2013 Passat TDI SE in September 2013 because our kids were getting too big and didn't have enough leg room in the back of the Jetta.
I have serious concerns about the delay in acceleration on the new Passat. There have been several times when I thought I was going to get hit by oncoming traffic when trying to pull out or pull across traffic. The latest just happened on Sunday. I was pulling out onto a road where I couldn't see real far because it was on a bit of a curve, so I hit the pedal and it just started to pull out slowly at maybe 5-10 mph. My wife said "Well, you gonna go?". About that time, it kicked in and spun the tires. After I successfully pulled out, I said "I had it clear to the floor." I have talked to my VW dealer service department about this issue several times, and they've even test driven it, but of course they didn't see the problem. It doesn't do it that severely all the time, but about a month ago I was on a back road and was testing it. I was consistently getting 1.5-1.7 second delays before it would kick in and actually take off. With that kind of delay, an oncoming car traveling at 55mph would cover 128 feet in that time. It doesn't matter if I have it in Drive, Sport or Manual, they all do the same thing.
Has anyone else had this issue?
Thanks,
Kris
khenn is offline   Reply With Quote
Old August 26th, 2014, 06:19   #2
TheGrove
I would recommend doing a search as this has been discussed several times within the past couple months. It has to do with getting used to how the DSG engages. It does not like having the pedal pushed to the floor you need to roll into the throttle and as it starts to move you can push it on down and it will accelerate quickly.
2012 Passat SEL Premium TDi Opera Red - Dieselgate Fix, KermaTDI Tune
2004 Passat GLS TDi Northern Green RC Stage 2 Chainless - RIP
TheGrove is offline   Reply With Quote
Old August 26th, 2014, 06:26   #3
khenn
Thanks, I did search prior to posting, but must have been using the wrong terms. I searched for DSG and found some threads. Thanks again!
Old August 26th, 2014, 06:43   #4
Sigforty
I personally just come of the brake a few seconds before I hit the gas. That always gives the DSG time to engage. It took a little getting use to, but now I have it down after a year of driving. You will see the same delay if you come off the gas and coast then have to get into the accelerator.
Sigforty is offline   Reply With Quote
Old August 26th, 2014, 06:44   #5
DubFamily
Fuel Economy: It's still a diesel!
khenn; if you still feel the delay is bothersome you can also try a DSG tune. It will eliminate a lot of the delay (not all; part of it is due to electronic throttle) and make the DSG more responsive.
-Jason G
Originally Posted by kjclow View Post
Dub said it better.
2014 BMW 328d xDrive
Member SSBMWO
DubFamily is offline   Reply With Quote
Old August 26th, 2014, 09:00   #6
jrm
Fuel Economy: 42/52
Sport mode fixes a lot of it, or just take your foot off the brake and hold the car with the hand brake. If your on a incline of any time the delay may be hill hold
2015 Passat TDI SEL
2013 Passat TDI SE+NAV 48MPG (totaled)
2012 Ram 2500 Longhorn 15MPG tops
2009 Highlander Hybrid aka the HIHY 25MPG
1996 Dodge mechanical Cummins 12V 2500 4x4
jrm is offline   Reply With Quote
Old August 26th, 2014, 09:25   #7
ChadS99SVT
as the others have said it's just something you have to get used to. It's a quirk of the DSG transmission.
It is annoying at times but I've adapted and i just excellerate a second or two early and never have any issues.
ChadS99SVT is offline   Reply With Quote
Old August 26th, 2014, 10:24   #8
APT
Your situation could have a couple different things. There can be a little lag while first gear is engaged. But if I accelerate quickly it will accelerate quickly. However I suspect you are slipping second gear which takes longer and feels slower until engaged and boost comes on. The DSG in Drive mode slips second gear from about 2mph it seems. Unless I come to a complete stop for at least one second, it seems to "start in second". So maybe at a left turn signal you idle creep a couple seconds then hit the accelerator, you are slipping second gear. Sport mode shifts into and holds first gear longer which should improve your situation. So would manual mode.
I would try to find another owner to meet with and test.
2012 Passat TDI SEL Night Blue/Cornsilk
2017 Subaru Outback 3.6R Limited Lapis Blue
2011 Suburban 2500 family towing beast
APT is offline   Reply With Quote
Old August 26th, 2014, 11:01   #9
jhinsc
Just like a manual transmission, there is a momentary delay in engaging the clutch in the transmission from a stop, except in a DSG, it's doing it automatically. Sometimes I feel it when taking off from a stop. The engine will rev slightly then come back down as it fully engages, just like it would do if I was letting up on a clutch. Knowing that, you do have to pick the times when you need to scoot across an intersection or not. Like other's have stated, lifting off the brake pedal a second or two before you need will help prevent the delay. If you look at pros and cons of the DSG, this is one of the cons, but on the pro side, you get quicker shifts, and better fuel mileage versus a traditional auto transmission.
jhinsc is offline   Reply With Quote
Old August 26th, 2014, 11:04   #10
tdiatlast
khenn: Keep in mind the DSG does NOT like rolling stops. If you can't come to a complete stop, pop it into S or Tip.
2014 Passat TDI, 2009 JSW TDI DSG (buyback)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
2017 Ford Energi Titanium, purchased 12/15/18
tdiatlast is offline   Reply With Quote
Old August 26th, 2014, 11:30   #11
cevans
TDI Parts Ninja Vendor
cevans's Avatar
You hit the nail on the head. The 5-10 MPH gap is where the DSG is shifting from 1st to 2nd. Sounds like the OP is trying to floor it while the car is shifting into 2nd, and his instant throttle request is causing the DSG to try and shift back into first.
FWIW - I put this on the driver. Every automatic transmission is going to have points where you can "confuse it". You ask for something that it isn't ready to do, you'll have problems. Don't floor any automatic transmission between shifts, learn where the "kick down" point is so that you can apply as much throttle as possible without downshifting. It took me 2 weeks to get the hang of my DSG sportwagen, but now I love it.
IDParts.com - IDParts.com Vendor Thread - The IDParts Blog - IDParts YouTube Channel
Current Diesels: '17 Canyon 2.8L DMax, '15 Jetta, '15 Beetle Convertible, '11 R350 BT // Past: 15' Ram ED, '13 NMS, '10 JSW, '10 Jetta Sedan, '07 R320 CDI, '06 E320 CDI, '03 Wagon, '00 Golf 2-Dr, '00 NB (Yellow :-)
Stop Hunting for Torque Specs - Get A Free IDParts Torque Spec Poster Today!
cevans is offline   Reply With Quote
Old August 26th, 2014, 12:12   #12
tdiatlast
Even the most experienced manual drivers get confused in the 5-10mph range, and have to work at smooth engagement of 1st gear. My 09 JSW (OEM mechatronic) would dutifully drop into 1st if I provoked it, instantly revving above 2k, and then the 1-2 shift would SLAM, once causing my daughter to scream that she thought someone had rear-ended us.
VW replaced that mechatronic at 17k miles, the replacement still does it, to a lesser degree, as a reminder that 2-1 downshifts, with such a short 1st gear, just aren't a good idea.
So, flash forward to 2012, and the engineers at VWoA softened up the issue by effectively locking out 1st (my interpretation of it, maybe not an actual fact!), hence the clutch-slipping SLOOOW response with a rolling stop.
Old August 26th, 2014, 19:08   #13
pparks1
While I have felt the delay, I've never once felt that it put me into a non-safe situation. Honestly, if it gets that close, it's my fault.
Sadly, my 2013 Passat TDI was hit while parked by a driver who fell asleep and it was declared a total loss by insurance. This happened on 8/10/2016, so I didn't see a dollar from VW for either a fix or a buyback, as I was excluded from the settlement. My daily driver is now a 2016 Honda Accord EL-X sedan.
pparks1 is offline   Reply With Quote
Old August 27th, 2014, 03:30   #14
Lightflyer1
Lightflyer1's Avatar
My experience mirrors pparks1. Don't pull out in front of someone who is going to hit you if you don't floor it immediately to get out of the way.
Old August 27th, 2014, 04:29   #15
skinnyb
TDI(s): 2013 JSW TDI
Fuel Economy: Slightly north of 40 MPG
Same here. The dsg is a totally different animal and paired with a turbo engine it takes some getting used to. My JSW and Passat behave the same way whereas my R32 is much different (NA gas engine with dsg) .
2015 Passat 1.8T Limited Edition
2013 JSW TDI DSG Malone 2.0 Eco, Tint, Wheels, Etc...
skinnyb is offline   Reply With Quote
New 2013 Passat TDI SE Owner NickBeek VW Passat Family (NMS and B7) TDIs (2012+) 21 August 2nd, 2013 08:01
New 2013 Passat TDi SE w/ roof flyman1981 VW Passat Family (NMS and B7) TDIs (2012+) 7 July 2nd, 2013 19:11
New 2013 Passat TDI SE w/ SunroofTDI knighthawk VW Passat Family (NMS and B7) TDIs (2012+) 16 February 5th, 2013 06:15
New 2013 Passat TDI SE w/Sunroof socomo65 VW Passat Family (NMS and B7) TDIs (2012+) 9 January 29th, 2013 06:49
2013 VW Passat TDI SE rmd0311 Passat TDI Picture Gallery 8 September 29th, 2012 07:23
Page generated in 0.18454 seconds with 11 queries
[Output: 128.35 Kb. compressed to 107.27 Kb. by saving 21.08 Kb. (16.42%)]
