Old January 3rd, 2014, 09:59   #1
Tsquare86
Default Oil Filter Housing Blowout - No Oil in CAR!?!?
Gents, Ladies,
Walked out this morning in the -15F temps and started the Jetta to let it warm up before going to work, went inside and did a little scrub a dub, and then came back out to hear my lifters clacking like all hell was breaking loose. Walked in front of the car to see a 6' round puddle of oil on the driveway. Immediately shut off the car, checked the oil, and then put a gallon back into it... Ugh...
Found out the oil filter housing oring must of junked out with the cold temps and viscous oil as it was spewing out after I filled the car back up and restarted.
Question: These engines are pretty robust and I didn't notice the oil pressure warning light on, but I'm really concerned about my lifters being hosed after this. Anyone have a good list of things to check? Headed to China for 2wk starting tomorrow, so won't be able to check everything before I leave.
15 GSW 6MT
Prior: 1999.5 Black Jetta TDI
EGR Delete, Cat Delete, Muffler Delete, VR6 Front Springs, Wagon Rear Springs, 2" Billet 6061 Spacers ->4" Lift with an attitude! Sprint 520s, RC2
Tsquare86 is offline   Reply With Quote
Old January 3rd, 2014, 10:05   #2
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
I think you'll be O.K. When you get a chance do an oil change and look for small flecks of metal.
Old January 3rd, 2014, 10:14   #3
Ski in NC
Fuel Economy: 48-52 typical
Engine is probably ok. Maybe. Depends on how long it was run without oil. Cold oil is nearly grease, and greased bearings don't need pressure lube. Nothing to do but fix the leak and see what it does.
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old January 3rd, 2014, 10:49   #4
snakeye
snakeye's Avatar
Are you sure the clacking wasn't due to the cold?
When i busted my oil pan a few months ago, i drove home not knowing i had a leak. Oil pressure light never came on, but I'm pretty sure my engine was almost dry by the time i parked in the driveway. There was a puddle but not too big.
Upon changing my pan, i tried starting my engine, but it wouldn't even crank at first. After numerous attempts it finally cranked slowly and eventually fired up, but smoked like crazy. Thought it was ruined, but the next day i stated it up again and it didn't smoke at all.
Was a close call. The fact that my car wouldn't even crank, and that yours started, makes me think your car may just be alright.
snakeye is offline   Reply With Quote
Old January 3rd, 2014, 17:50   #5
Tsquare86
Friends! Managed to replace the two orings in about 40 min (inclusive to pushing car into garage with truck and turning on the old kerosene heater). No more leaks and lots of residual sprayed all over the front of the engine.
Again these damn engines amaze me. I can't believe how much more oil I had to put back into this thing. Filled it up, cranked over and ran like a champ, no lifter clicking at all.
Gives me faith I will hit 360k :-D (even with my dirty habits) and hello Asia tomorrow
15 GSW 6MT
Old January 3rd, 2014, 18:11   #6
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
The oil pressure light doesn't work at idle because the gauge cluster ignores the sensor under 2000RPM. So basically you can have no oil pressure and unless you rev the engine over 2K, you will never know until it locks up. Nice huh?
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 395K miles and climbing.
09 Jetta Gasser, autofailmatic. Backup car. 230K.
turbocharged798 is online now   Reply With Quote
Old January 3rd, 2014, 18:50   #7
AndyBees
AndyBees's Avatar
The lifters were whacking because there was not oil pressure.
I do agree that your engine is probably okay. At idle, the rod bearings would be the first to suffer. But, as Ski in NC said, the cold oil acted as grease...... lubing those moving parts.
About two years ago, I did extensive work to a 1.8T Passat that had lost oil pressure due to plugged oil pump screen. The lifters were whacking like crazy, the plastic timing chain tensioner for the second Cam was toast, etc...... New oil pump, cleaned out oil pan, etc., and two years later, the engine runs fine!
This is the TDI Club, a place to share experiences & ideas, ask for help, etc. Welcome Newbies! Sarcastic and condescending posts shouldn't be welcome.
Old January 3rd, 2014, 18:58   #8
CopaMundial
Off topic to the original question but idling to let it warm up, does that actually accomplish anything?
Welcome to the TDIClub forum. If this community forum helped you save money on a purchase or repairs, please consider donating just a small percentage of what you saved using the 'donate' link HERE. Donations keep the forum going. (note: I'm not affiliated with TDIClub or Fred... I just can't imagine the world without either of them)
CopaMundial is offline   Reply With Quote
Oil Leak....cracked oil filter housing invader VW MKV-A5 Golf/Jettas 2 March 6th, 2013 07:14
Oil filter housing leak nashbok VW MKIV-A4 TDIs (VE and PD) 2 February 18th, 2013 20:00
Oil filter housing leak Eoghan TDI 101 4 February 1st, 2013 08:26
ALH oil pan, oil filter housing, misc. coolant lines storehouseassets Private TDI Items for Sale/Wanted 4 February 21st, 2012 16:20
Coolant leak under the oil filter housing. snakeye VW MKIV-A4 TDIs (VE and PD) 8 March 11th, 2011 17:11
Page generated in 0.15622 seconds with 11 queries
[Output: 88.45 Kb. compressed to 76.38 Kb. by saving 12.07 Kb. (13.65%)]
